-   -   Noticed some oil in intake hose before inter cooler (http://www.wrxtuners.com/forums/f70/noticed-some-oil-intake-hose-before-inter-cooler-39777/)
DS07Turbowagon 09-29-2013 09:49 PM
Got an 07 WRX as I was changing out my clutch I took my inter cooler off and found SOME oil inside the intake hose from engine to intercooler. It wasn't much just coated the bottom of the hose about 1.5 inch wide section. Any ideas if there's is an issue here?
turmic 09-29-2013 10:07 PM
Probably just blow bye...you'll always have a little. But, if it's pooling up or a lot i'd be worried. A little isn't much to worry about.
n8mcd 09-29-2013 10:47 PM
It's normal I'm pretty sure, Most cars have PCV valves that rerout back to the intake, that's why people buy valve cover breathers or catch cans, the oil definately reduces efficiency of the intercooler. Now if there's a lot you might have worn rings or valve seals. But some is normal
DS07Turbowagon 09-30-2013 01:18 AM
Thanks it's definitely not pooled nor was it dripping out of the hose it was just wet.
BLAZE2099 09-30-2013 05:18 AM
That's normal, you can stop panicking.
turmic 09-30-2013 09:51 AM
Or AOS systems to try and reduce the blow bye a tad.
