new turbo ATP GT3071 - Subaru WRX Forum
post #1 of 17 Old 01-12-2008, 07:24 PM Thread Starter
nicolas316 is an unknown
please guys i really need you to help me out hear. my 07 2.5 WRX, has a 75mm catless down pipe, center pipe, and turbo back, k&N tayphoon, ecutek, and warlbro fuel pump. NOW its time to change my turbo. what i am looking for is a turbo with fast spoot up and not a lot of lag becuase where i need it the most is on our roads here in lebanon which are mostly mountain roads, so i mostly am in 2nd and 3rd gear and i have sharp turns which means i need my turbo to be ready to perform on rpm's close to stock. another point is that i wont be running more than 19psi on my car because im scared to blow up smth in my enging or so. Gruppe-s advised me with the ATP GT3071. what do you guys say, thanks.
Nicolas,.
nicolas316 is offline
post #2 of 17 Old 01-12-2008, 07:37 PM
wrxman420's Avatar
If you don't want a lot of lag, I would suggest something a little smaller than a 30R. Do you have upgraded fuel injectors an intercooler?
wrxman420 is offline
post #3 of 17 Old 01-12-2008, 07:52 PM Thread Starter
no not yet, im planning on putting sti TMIC. ## saying the gt3071 is too big? on what rpm does it start spooling? before 4000rpm?
post #4 of 17 Old 01-12-2008, 07:59 PM
wrxman420's Avatar
It will start spooling before 4000rpm, depending on how much your gunna boost it you may reach full boost before 4000 or you may not. I would recommend a big timc since the sti tmic is not that much bigger than your wrx tmic. The less boost you run the faster it will spool.
post #5 of 17 Old 01-13-2008, 12:43 AM
I still don't know if he's got a USDM or JDM motor in that thing.
post #6 of 17 Old 01-13-2008, 03:16 AM
wrxman420's Avatar
It says he's from asia, so i'm guessing JDM. What does your car redline at 7k or 8k?
post #7 of 17 Old 01-13-2008, 05:55 AM
Longshot's Avatar
Don't listen to Gruppe-s, their reputation has plummeted over the last year. I wouldn't do any business with them. Also I didn't see modded or bigger injectors on your list. Don't forget those.
DTRacing Tuned
Longshot is offline
post #8 of 17 Old 01-13-2008, 07:06 AM Thread Starter
my car is a european spec it redlines at 6500rpm up to 8000rpm. for what im looking for will the gt3071 do the job or not? i will need fuel injectors and a bigger tmic?
post #9 of 17 Old 01-13-2008, 09:45 AM
It not always has to do with boost pressure,it's airflow to.Why does everyone want to run this big arse turbos with stock cams,heads and throttlebodies.Un-efficient You see big #'s but so much is being lost.You would get more running a smaller turbo to it's max potential and it would cost much,much less.
dumdum is offline
post #10 of 17 Old 01-13-2008, 09:55 AM Thread Starter
so which turbo will you propose dumdum? 330-350hp will satisfy me. i want a turbo which will perform well on 18-19psi and spool up close to stock, and not ruin my engine internals. what do you reccomend? what do you think about Forced Performance Green Turbo ? and the Forced Performance TD06 20G ? these are at gruppe-s. thanks guys for your help.
post #11 of 17 Old 01-13-2008, 10:18 AM
Well are we talking chp/bhp or wheel hp?Chp/bhp (crank hp/base hp) the stocker can do that.WHP(wheel hp) I would go with a EvoIII TD05-16G.The turbos you are picking are way big.The bigger the turbo,the more lag.You can't have your cake and eat it too.Doing things like sticking with a TMIC,3 port boost solenoid,EL header and port/polish/ceramic coating will improve spool up and power through out the powerband.
dumdum is offline
post #12 of 17 Old 01-13-2008, 10:29 AM Thread Starter
im talking bhp. im not going to change engine internals now. the turbos i mentioned before are too big? what are my options thenn?
post #13 of 17 Old 01-13-2008, 10:35 AM
I just told you.
dumdum is offline
post #14 of 17 Old 01-13-2008, 01:17 PM
wrxman420's Avatar
I would suggest going with an evo 3 16g.
post #15 of 17 Old 01-13-2008, 01:19 PM
Longshot's Avatar
^^ That's where I'll be headed when the time comes.
DTRacing Tuned
Longshot is offline
