my cobb apv2 settings throwing cel's - Subaru WRX Forum
post #1 of 5 Old 11-02-2007, 10:38 AM Thread Starter
numark1510's Avatar
Unhappy my cobb apv2 settings throwing cel's
i was messin with my ap thursday and set it to the stg 1 map (regular not hwgd),more precicely i reflashed it to stg 1 and set the on the fly map to stg 1 as well. i was driving along evrythings fine and dandy ,then my cel starts flashing then stays on.i check the codes and it says cylinder misfire. does anybody have any idea on what this is and how i should go about fixing it.in the meantime i put the on the fly setting to married stock mode.
numark1510 is offline
post #2 of 5 Old 11-03-2007, 12:33 AM Thread Starter
numark1510's Avatar
the cel went off after i set it back to stock mode.
post #3 of 5 Old 11-03-2007, 11:15 AM
Longshot's Avatar
Why are you at stage 1 with your mods??? With the catless DP alone you should be at stage 2. What is going on here???
DTRacing Tuned
Longshot is offline
post #4 of 5 Old 11-03-2007, 12:02 PM
Wow, didnt look at your mod list, if you have a catless DP or aftermarket one in general you should be running the AP stage 2 map, if not a protune on top of it. That would probaby help with the CEL and you will have more power also.
post #5 of 5 Old 11-03-2007, 02:00 PM
agreed. set it to stage 2
darthsofearu is offline
