might be buying used cobb AP... - Subaru WRX Forum
post #1 of 22 Old 10-11-2007, 06:48 PM Thread Starter
Images: 14
Labukas19 is more helpful than not
the guy said it was off of a 2004..
heres what he said... " am pretty sure that it is married and it has the basic tunes in it( stage 1, stage 2 both with 91oct and 93 oct) It also has econo and some other programs. "
can i use the AP?
i dont wanna buy it if i cant uses it lol... how can you tell if you can or not?
any help is appreciated!
thanks!
2001 COBRA
Labukas19 is offline
post #2 of 22 Old 10-11-2007, 06:51 PM
wrx3r's Avatar
wrx3r is more helpful than not
dont buy it unless he KNOWS its unmarried
bigger and better than ever
wrx3r is offline
post #3 of 22 Old 10-11-2007, 07:00 PM Thread Starter
Images: 14
un married as in his car has been flashed back to stock right? can i uses his MAPS? the stage 2 and ect...
how about cobb AP from other years? my buddy has one from an 04 STi.. what can i do to make that work? flash his back to stock then what?
thanks!
2001 COBRA
post #4 of 22 Old 10-11-2007, 08:26 PM
You cant use the STI one, but if the other one is unmarried you can use it without a problem.
post #5 of 22 Old 10-12-2007, 07:05 AM
Longshot's Avatar
As long as the Stg 2 and etc. map are the OTS ones, then you should be fine.
DTRacing Tuned
Longshot is offline
post #6 of 22 Old 10-12-2007, 07:36 AM Thread Starter
Images: 14
yea but i can get the one from the sti for free b/c he owes me money... how do i go about flashing my car with that one? take his back to stock? then just flash mine?
i though sti maps were different...
2001 COBRA
post #7 of 22 Old 10-12-2007, 07:37 AM Thread Starter
Images: 14
and what is ots? and how do you tell?
2001 COBRA
post #8 of 22 Old 10-12-2007, 02:28 PM
wrx3r's Avatar
you CANT use the sti one. the sti ecu and wrx ecu are not the same...at all.
wrx3r is offline
post #9 of 22 Old 10-12-2007, 02:50 PM
Longshot's Avatar
He's right ^ you cannot use the STi one. OTS stands for Off The Shelf maps, which are general maps created for a vehicle specific ECU. They are not customed to your own vehicle just the model. If it's a "staged" map from COBB its probably an OTS map, but keep in mind tuners us the AP for custom tunes. You can go on COBBs website and lookup the names of the OTS maps and try an match it to whats in the AP.
DTRacing Tuned
Longshot is offline
post #10 of 22 Old 10-12-2007, 03:07 PM
The STI engine is also different from your car also, you have the 2.0 where as the STI has the 2.5, but like also stated the ECUs are different.
post #11 of 22 Old 10-12-2007, 05:24 PM Thread Starter
Images: 14
yea i misread the sti ap workibg.. i figured it wouldnt. also it being drive by wire...
thanks for the help so far! will talk to the guy and see what he says!
2001 COBRA
post #12 of 22 Old 10-29-2007, 02:36 PM Thread Starter
Images: 14
alright guys, found a deal on another one... the guy said he put it back to stock. said its stage 2... how can you tell if its stage2 or stage1? he also had an 04 wrx. so i can just use his maps right?
thanks!
2001 COBRA
post #13 of 22 Old 10-29-2007, 03:00 PM
Longshot's Avatar
thanks!
If it's an 04 rex it'll work for your car. The guy you are buying it from said his car was at stage 2? If so then he just unmarried it from his car and it should be fine for you. The AP itself isn't stage 1 or 2 (not sure if i quite understand your question), the OTS maps are stage 1 or 2, being the software itself. The AP is just the unit to transfer that software from COBB to your ECU. You CAN use his maps if they are just the OTS ones from COBB's website. You CANNOT use his maps if he got a protune done with the AP at a shop. Either way you can simply download whatever maps you need from COBB then flash them onto your car.
DTRacing Tuned
Longshot is offline
post #14 of 22 Old 10-29-2007, 04:51 PM Thread Starter
Images: 14
yea i know the AP is just the "tool" to flash my car... just wanted to know if there was a way to tell which tune was in it... how much is it to get one of those tunes from ots? and the AP will come with a computer hook up right? thanks!
2001 COBRA
post #15 of 22 Old 10-30-2007, 02:57 AM
There is a list of tunes that come with an AP at Cobbs website. The OTS maps are free, dont cost a thing, they are the maps that come with an AP from Cobb. The AP should come with a cable that hooks the AP to the OBDII port of the car, and can also be used to connect the AP to a computer.
