Max torque the stock internals can take - Page 2 - Subaru WRX Forum
post #16 of 22 Old 01-08-2008, 08:51 PM
uh guys, many of us are talking about two different engines here.
The WRX 2.0L puts about the same peak torque down as hp
The WRX 2.5L puts down considerably more torque down than hp
The STi's 2.5L puts down a little more torque than hp.
Course any tune can change things slightly.
BTW: That dyno chart is an 06 or 07 WRX definately
post #17 of 22 Old 01-08-2008, 08:55 PM
wrxman420's Avatar
I don't know if you guys have seen this but there is a bugeye with 477awhp on the stock 2.0L ej20.
Andrewtech + TurboXS SICK STOCK 2.0 w/Gt30r - Proven Power Bragging - NASIOC
wrxman420 is offline
post #18 of 22 Old 01-09-2008, 01:25 AM
MilesFox's Avatar
generally soob motors prodice more torque than horsepower. this is due to large diameter pistons which give good push ans a short crank, so more of your displacement is piston than stroke. this makes for a powerful push and the short crank allows for the high rpms.
plus the firing oder is 1324 on each bank both pistons fire almost simultaneously, one piston is firing just as the other one is on its way to bdc. and alternately between both sides you have a "siamesed" power stroke and thus its almosts like 2 very large pistons,and this is why it sounds like a harley when it runs with blown out exhaust gaskets.
observe
ea82
* Displacement: 1781 cm³
* Bore: 92 mm
* Stroke: 67 mm
* Compression Ratio: 8.7:1 or 9.0:1 SPFI
* Valvetrain: SOHC
* Horsepower: Carb - 84@5200, SPFI - 90@5600, MPFI - 97@5200
* Torque: Carb - 101@3200, SPFI - 101@2300, MPFI - 103@3200
ea82t
Additional Specifications
* Turbo: IHI Corporation model RHB5 VF7
* Compression Ratio: 7.7:1
* Supercharging Pressure: 7 psi
* Horsepower: 111@5200
* Torque: 134@2800
er27 (xt6)
Specifications
* Displacement: 2672 cm³
* Bore: 92 mm
* Stroke: 67 mm
* Compression Ratio: 9.5:1
* Valvetrain: SOHC
* Horsepower: 145@5200
* Torque: 156@4000
as you can see the torque is more than the horsepower, and occurs at lower rpms. and if you compare the turbos spec the toque occurs greatest at the lowest rpm. whatever the HP rating is at 5252 rpm the torque curve will match it there.
so with the er27 you have 156 tq at 4000 rpms and 145 hp at 5200 rpms, you will actually have 145 tue at the top of the horsepower curve since it lands at 5200 rpm
MilesFox is offline
post #19 of 22 Old 01-09-2008, 06:47 PM
silverSTi's Avatar
Originally Posted by 7055 View Post
hello, wondering what the most torque to the wheels an STI motor can take on stock internals before you risk breaking something in the motor. preferably in torque.
in the january issue of modified mag, AMS performance was able to get 350whp and 401wtq on stock internals on a 05 STi. the only mods it had was CAI,DP,CBE, and a protune done by AMS
there tuning wa a little extreme i thought, they claimed to be running 21psi by reflashing the ECU
Byron
silverSTi
silverSTi is offline
post #20 of 22 Old 01-09-2008, 07:51 PM
That is about as useless a powerband as I have ever seen. Although it does make some crazy power.
One way to find out how much "your" cars internals can handle, bolt on everything make alot of power and when the motor lets go you know you have found the magic number for "your" car.
post #21 of 22 Old 01-09-2008, 08:21 PM
^^Thats pretty much the only way to truely tell. Expensive if you ask me, but a gurantee, lol.
post #22 of 22 Old 01-09-2008, 08:25 PM
Dom, our tuner was tuning his 07 STI tonight at my work and he has 350 WHP and 390 WTQ on a mustang dyno, and thats on stock internals.
nagyhead is offline
