learning view - Subaru WRX Forum
post #1 of 10 Old 04-12-2012, 10:27 AM Thread Starter
pipe1 is an unknown
learning view
anybody care to take a look at my first learning view.
pipe1 is offline
post #2 of 10 Old 04-12-2012, 11:18 AM
you should use Rom Raider
post #3 of 10 Old 04-12-2012, 11:55 AM
What program IS that?
post #4 of 10 Old 04-12-2012, 12:19 PM Thread Starter
pipe1 is an unknown
yes i do use rr. i keep reading up in different forums i constantly see learing view being mentioned. so i thought i would give it a try. my 03 wrx has catless uppipe tbe panel filter and os tune.
pipe1 is offline
post #5 of 10 Old 04-12-2012, 12:19 PM
Paul its called Learning View
post #6 of 10 Old 04-12-2012, 12:21 PM
the nice thing about it is that it shows logging data in a nice view, the major problem is it doesn't show enough info
post #7 of 10 Old 04-12-2012, 01:01 PM
Learn something new everyday.. .Thanks Matt.
Bet that's nice for someone just learning.... Hence the name...
post #8 of 10 Old 04-12-2012, 03:39 PM
Also the only way to disable/read DTC's with a Tactrix cable.
Basically you NEED Learning View, Romraider, and ECUflash to properly tune a Subaru opensource.
post #9 of 10 Old 04-23-2012, 02:42 PM
Little late but everything looks very good. I would change the "Y" axis for better resolution. This is done by modifying the ROMs "fine correction-rows" in the "Ignition-Knock Correction" section. Obviously your car will never see 12k rpm.
dumdum is offline
post #10 of 10 Old 05-09-2012, 03:15 AM
Alexmartynyuk's Avatar
Alexmartynyuk is an unknown
what was weather like? you should datalog instead using romraider. find a flat/straight road and do a 3rd gear log from 2-7k then post the log. Make sure you're not heat soaked too.
Alexmartynyuk is offline
