knock light - Subaru WRX Forum
post #1 of 17 Old 10-17-2008, 06:28 PM Thread Starter
goofoff's Avatar
goofoff is an unknown
knock light
ok so i have a utec system. every once in awhile when i get on it the check engine light flashes, i know thats the knock light. i tried lowering boost to see if that would help, but nothing still did it. now i guess what i'm asking is, is there a good write up on the utec system cause i cant log on to it with my computer. it wont connect. when i was reading, i read that i need to adjust my timing and fuel cause its denating. i plan on getting the car tuned soon, was going to go to pdx but was wondering also if anyone in the western washington area knows of a good place near by. any help would be appreciated, i dont want to blow my motor. any time i see it flash i let off the gas.
goofoff is offline
post #2 of 17 Old 10-17-2008, 08:09 PM
There is Kito up in Seattle, and Pacific Import Auto. Supposedly Tim Bailey comes by PIA once and awhile to tune cars. Thats where I will go to get my protune when Im ready for it.
post #3 of 17 Old 10-26-2008, 09:11 AM
If the "knock light" is coming on at low loads and rpms it is probably false knock (road noise).If is up high under WOT i would try adding an octane booster just to see if it is the gas.
dumdum is offline
post #4 of 17 Old 10-26-2008, 12:22 PM
Dom doesn't tune for kito any more so i don't know who is tuning there. there is also Dyno Authority in Redmond.
nagyhead is offline
post #5 of 17 Old 10-26-2008, 02:07 PM
Stefan's Avatar
Stefan is an unknown
Send a message via AIM to Stefan
Octane boost is a joke...That stuff doesnt work at all....
Stefan is offline
post #6 of 17 Old 10-26-2008, 07:35 PM
Octane Booster Reviews
Depends on the one you buy.You don't need 104 octane to change detonation.Even 2 octane points can make a difference.You can also go down to your local hardware store and buy some tolulene to slam in the tank and it works.
dumdum is offline
post #7 of 17 Old 10-27-2008, 01:42 AM Thread Starter
goofoff's Avatar
you dont think that putting an octain booster will effect the base map on the utec. running 18lbs of boost.
goofoff is offline
post #8 of 17 Old 10-27-2008, 10:01 AM
Not sure what your question is ...do you understand what octane does and how it works?Less of it causes a problem,not alittle more of it.If you don't want to do that then learn to datalog the car and pull timing from the area where the knock is happening.Should be pretty obvious where it is by looking at feedback and fine knock correction or where IAM has changed.
dumdum is offline
post #9 of 17 Old 10-27-2008, 06:14 PM Thread Starter
goofoff's Avatar
i cant log on to the utec from my laptop. i think my usb adapter is a crappy one. whats the worst thing that could happen if i put the octane booster in? I'm not sure if my Car is set up for 92 octane (premium). still new to this whole turbo thing, but loving every minute of it.
goofoff is offline
post #10 of 17 Old 10-27-2008, 06:52 PM
Hell yes it's set up for premium! What are you putting in there?!?!?! The car is 91 MINIMUM! 93 would be safer if you have it.
post #11 of 17 Old 10-27-2008, 07:01 PM
Slithgtly higher octane will definitely NOT have any bad side effects. On the contrary, it can only help you.
WReXd is offline
post #12 of 17 Old 10-27-2008, 11:11 PM
Speaking of this, off a little, some idiot tried to put 89 in my car the other weekend in Oregon. I almost punched him, lol. But try the simple things first before going for the big expensive ones. Start with some octane booster and go from there.
post #13 of 17 Old 10-28-2008, 12:47 AM Thread Starter
goofoff's Avatar
Yes everytime i put premium in. I'm not that stupid. It even says on the gas door Premium. Next fill up i'll throw in some booster. Any suggestions?
goofoff is offline
post #14 of 17 Old 10-29-2008, 10:46 AM
Only posted this earlier in this thread...... Octane Booster Reviews
dumdum is offline
post #15 of 17 Old 10-29-2008, 04:13 PM Thread Starter
goofoff's Avatar
Just filled up, put some stp octane boost and so far no knock light. hopefully this works.
goofoff is offline
