Knock-Knock? Knock/Tuning Strategy Discussion - Subaru WRX Forum
 5Likes
  • 2 Post By Ruso
  • 1 Post By Ruso
  • 2 Post By titter
post #1 of 5 Old 02-15-2017, 03:21 PM Thread Starter
Ruso's Avatar
Ruso is more helpful than not
Lightbulb Knock-Knock? Knock/Tuning Strategy Discussion
Dear Gents (and Ladies of course). I'm starting a discussion about.... you guessed it, knock! More importantly, tuning strategy to avoid knock and what levels of knock are considered acceptable.
I want to start out by stating some points and hopefully we can all pitch in information and clarify based on real world experience, some tuning strategies and how to keep our engines running safe and strong.
I will keep updating this thread as new information/experience comes in.
Please, only contribute if you have real world experience. Let's try to refrain from re-posting other things that are commonly said on the internet because I want to avoid the broken telephone effect and shatter some common myths and bring clarity about the subject.
1). A lot of tuners and big OTS map companies (Such as COBB) suggest that Fine Learning knock is completely acceptable and recommend their users to basically ignore it unless it's over x... amount (As long as DAM/IAM doesn't decrease)
-Although Feedback Knock is a response to a single knock event and catches false knock all the time, Fine Learning Knock, registers due to persistent knocking in a specific region of the map.
-Once a fine learning value is "learned" by our ECU, the Timing is pulled for that area of the map and stays there until it is unlearned, slowly over a period of time, unless knocking in that area of the map persists in which case it will go back up.
-Fine learning of say -2.81 degrees means -2.81 degrees will ALWAYS be pulled from that area of the map UNTIL that area of the map is unlearned. My understanding is that if the car is always over 2 degrees (for example) of timing, that's a HUGE power tax on that cell.
-FLK affects LARGE areas of the map. By that I mean, each cell in learning view is nearly 1k in RPM range, and varies in load, but anywhere from .2 to 1 unit of load.
-FLK can be fixed in said cell by pulling only -.5 degree of timing a lot of the time (or even less). -.5 degrees of timing is significantly better than 1.4 or 2.8 or even 4.2 degrees of FLK.
2). DAM/IAM What is it? Is it a good indicator of a healthy motor?
(Copied from RomRaider website)
"Ignition Advance Multiplier (Dynamic Advance Multiplier on AP)
The ECU can adjust IAM in response to knock, and this value is used to scale the entire timing advance map. Because it effectively adjusts the entire timing map at once (as opposed to adjusting for a single RPM/load cell), it is presumed to be intended to compensate for varying fuel quality (e.g. if the owner fills up with low-octane fuel).
IAM is just one of several variables that contribute to the total ignition timing.
On 16-bit Subaru ECUs, IAM is an integer that varies between 0 and 16.
On 32-bit Subaru ECUs, IAM is a floating-point value that varies between 0 and 1."
3). Fine Learning Knock in low load cells VS full throttle cells
-FLK in lower load cells occurs during weird types of knock, such as tip-in knock (rapid changes in gas pedal position), EGR, false knock.
-It is safe to say (please correct me) that seeing any FLK in low load areas, is not anywhere as bad as high load (WOT) areas of learning view.
-(to me) it seems safe to also assume that ANY Fine Learning... OR persistent and regular Feedback knock (during smooth operation and gradually introducing WOT, rather than just pounding on the car) is not a good thing.
I will add more as it comes! Thanks for participating!
titter and Traves like this.
Ruso is offline
post #2 of 5 Old 02-17-2017, 07:36 AM
titter's Avatar
good stuff but i'll add one thing.
when doing these kind of technical explanations, you have to consider that everyone reading isnt as smart as you. most people reading this might not even know what a "cell" is.
maybe that should be part 2
dont forget to wave
titter is offline
post #3 of 5 Old 02-17-2017, 02:06 PM Thread Starter
Ruso's Avatar
Hey titter, absolutely. I want to first open up a discussion for other experienced members to chime in and collect it into the big post.
Once we have a good amount of content, I'll clean it up for the purpose of a Technical article.
I specifically am targeting it to experienced members with tuning experience for now to discourage random information regurgitation.
What do you think? I'm open to go in other directions too, as long as in the end I this turns into something to benefit the community.
Traves likes this.
Ruso is offline
post #4 of 5 Old 02-18-2017, 06:56 AM
titter's Avatar
i think its good. keep at it! more people need to understand knock. some people around me joke that FLK is FALSE Knock Learning since a good half of FLK events are usually false lol. there are some people dont even know the difference between rod knock and detonation knock.
if anyone wants to jumpstart their learning curve, i suggest they visit www.hpacademy.com and resgister. at the bare minimum, sign up for the FREE intoduction to tuning lessons.
RoboTuner and Traves like this.
dont forget to wave
titter is offline
post #5 of 5 Old 02-19-2017, 02:18 PM Thread Starter
Ruso's Avatar
titter I'm finally taking your suggestion (I've seen you say it before) and signed up and have been watching the webinars (the one on knock in particular). Good stuff, thank you!
One statement jumps out which is one of the main reasons I brought this up for discussion.
"A lot tuners feel that if the ECU has a knock control strategy that they don't need to worry about knock and really tuning the ignition timing isn't so important...
and that's simply not true.
A knock control strategy is simply no bandaid for a poorly tuned engine and we still need to do our job properly as tuners where we're actually optimizing the ignition timing".
Ruso is offline
