Go Back   Subaru WRX Forum: WRX Forums > WRX Tech Forums > Tuning & Engine Management
Old 07-15-2009, 07:21 PM   #1 (permalink)
Reputation: srninjastar is more helpful than not
i need a 3 port BCS
and to be honest, i have noo effing clue which one to get. i know that i need a retune and that it would help me with my major boost issues, but how will it effect the overall driveablity and performance of my car?
Old 07-15-2009, 07:58 PM   #2 (permalink)
Quicker spool, holding boost longer, thats about all I know, havent realyl heard of any ill effects of one. As far as which one to get, best to talk to your tuner to see what he is comfortable with.
Old 07-15-2009, 11:10 PM   #3 (permalink)
Timeslip: 9.999 @ 101.26
GS 3 port BCS is plug and play. No splicing of wires and comes with a bracket for your car.
All 3 port BCS work pretty much the same.
I went with the GS 3 port BCS and I like it.
Old 07-16-2009, 08:08 AM   #4 (permalink)
Car: 08 WRX
Reputation: Rfed is an unknown
I have a new HOA I will let you have for $50.
Old 07-16-2009, 10:25 AM   #5 (permalink)
c2bcoolwrx's Avatar
Car: 05 WRX
Club Region: Southeast
Reputation: c2bcoolwrx is more helpful than not
+1. Grimmspeed BCS is arguably the best 3 port BCS out there right now and the easiest to install, it comes w/everything (even a mounting bracket), and is noise free.
GrimmSpeed
Just make sure to choose the one for the '06-07 WRX.
Import Image has the GS BCS for $98 ($11 cheaper): Import Image Racing: Grimmspeed 3-Port Electronic Boost Control Solenoid
Old 07-16-2009, 03:05 PM   #6 (permalink)
i get my check from work today. so it looks like ima go on a small shopping spree
Old 07-16-2009, 09:57 PM   #7 (permalink)
Reputation: turmic is known to be trustworthy and helpful turmic is known to be trustworthy and helpful turmic is known to be trustworthy and helpful
Plug and play? Maybe easy install. But, I'm under the assumption that you've been tuned for it. Correct? Its that or you didn't pull the pill. With a 3 port. You don't need the pill. When you pull the pill....you'll need to adjust the WGDC tables. Because your wastegate duty cycles will be way to high for the 3 port. Which is why you should consult a tuner to properly tune it. Unless your really comfortable with messing with your tune.
Old 07-16-2009, 11:31 PM   #8 (permalink)
Yea I forgot to include that a tune is required. My tuner installed it and tuned it right afterwards.
Old 07-17-2009, 04:10 AM   #9 (permalink)
Reputation: Kjott21 is known to be trustworthy and helpful Kjott21 is known to be trustworthy and helpful Kjott21 is known to be trustworthy and helpful
Aftermarket Boost Control Solenoids
