I did a couple logs today, just wondering if someone would like to look at them and let me know how bad a need a tune? Mods include "EL header, Cobb CAI, catless UP, Cobb TBE, pulstar plugs, Turbo xs TMIC, HKS BOV" all running on a stage 2 map. I really want an aftermarket bpv because the stock one will not fit on my tmic. but anyways If you are good at reading these let me know. I have an AP race tuner program but I don't have the knowledge to tune myself...Thanks!
You could definitely benefit from a tune, theres a couple instances where it looks like it's pulling timing and your at almost stock boost level I would say your safe for a little while but you need to get a tune for that intake pretty soon
For some reason I can't get as much boost as I used to. A month or so ago I was getting around 17psi. Ive done a boost leak test and it sounds like there is air coming from the turbo...but my car is so inconsistent its not funny.
No, the last thing I did was put the header on about a month ago and it was fine...I did the boost test when I put my TMIC on "4 months ago" but it was still getting good boost. It just started the 15psi today...I noticed it wasn't as smooth so I did a few logs...
You have a serious issue with your car. Now the DAM is 9. DAM has to do with rough timing correction due to knock. The stock ECU programming starts the initial multiplier at 8. Cobb starts it at 12. If there is no issue a couple WOT pulls will bring it right up to 16.
I have been getting worse gas mileage than I used too...but even that is inconsistent...some days I get 22 on the hwy and some days its worse...Just like sometimes when I accelerate it feels like shit...
So I don't mean to de-rail this thread but I did some logs the other day as well. Can you guys tell me other parameters I should be monitoring when I pull a log? I'm trying to determine if I need a protune instead of a Stage 2 as well. I run the basic Stage 2 set-up (DP, Catback, SPT intake). The only thing extra is an STI intercooler that Cobb and P&L said was OK to run with the Stage 2 OTS map.
Can anyone take a quick look at my log and comment on what else I should add to the monitor list. Cobb's new firmware allows for some added monitoring now.
