help reading datalog...! - Page 2 - Subaru WRX Forum
 15Likes
post #16 of 26 Old 09-19-2013, 07:11 AM
Put the OEM BPV on there. If you don't have one, find one.
When doing a log, be on a level surface and when you are MASH the fookin gas at around 2800-2900 rpms and all the way up to just before redline.... don't just gradually go into it.
Post THIS log
boo-key and BLAZE2099 like this.
post #17 of 26 Old 10-09-2013, 04:11 PM Thread Starter
thekamikaze kid's Avatar
here is my new log, its hard to get a good strip of road arouind here, hopefully this one is better. the last time i was told by cobb my dam was supposed to be 16 and it is still 11, i hope this is due to the ecu learning the new map. oh and it seams i am hitting target boost not sure how to read the rest of this stuff so any help would be coo!
https://docs.google.com/spreadsheet/...mc&usp=sharing
thekamikaze kid is offline
post #18 of 26 Old 10-09-2013, 10:37 PM Thread Starter
bump, no one?
post #19 of 26 Old 10-09-2013, 10:50 PM
RayRay's Avatar
RayRay is an unknown
Your datalog looks fine, but you should log in 3rd gear and do a pull from 2500 rpm's to redline that way you will get a better read out of performance.
RayRay is offline
post #20 of 26 Old 10-10-2013, 07:22 AM
^this.... I gave you directions in my previous post.
boo-key likes this.
post #21 of 26 Old 10-10-2013, 07:51 AM Thread Starter
like i said not much flat road around here, this pull is in third gear at wot from about 2.5k-4.8k. its the best i could do. maybe ill see if i can get it to redline next week. thanks for the input and the patience.
post #22 of 26 Old 10-10-2013, 09:44 PM Thread Starter
well cobb reviewed my log and it seams that the dam is too low. when i asked if it could be a bov issue they said it could be. it was recomended that i see a mechanic. hopefully it is just the bov and nothing more expensive! anyway thanks fer all the help, and if anyone has any other comments or suggestions, good or bad that would be cool!
post #23 of 26 Old 10-10-2013, 10:12 PM
RayRay's Avatar
I was having problems with my aftermarket bov, threw the stock one back on and problems went away. Aftermarket bov...... FTL!
boo-key likes this.
RayRay is offline
post #24 of 26 Old 10-10-2013, 10:17 PM Thread Starter
what kind of problems were u having with your bov when u had it on exactly?
post #25 of 26 Old 10-10-2013, 10:36 PM
RayRay's Avatar
Air leaking through. Common problems with aftermarket bovs
RayRay is offline
post #26 of 26 Old 10-11-2013, 09:35 AM
This thread is giving me AIDS.
turmic and BLAZE2099 like this.
