help reading datalog...! - Subaru WRX Forum
 15Likes
post #1 of 26 Old 09-17-2013, 05:37 PM Thread Starter
thekamikaze kid's Avatar
ok i posted this first which is why i decided to datalog...
"ok so i have been having intermittent acceleration problems due to a possible wastegate issue. im getting a pause from the throttle and i have to let off the accelerator because it seams that the engine is about to cut out. I just went to cobb stage 1 and it seams to be a little worse than it was. i have looked up and down this site for info but if anyone has any literature or advice it would be cool considering i have a v2 access port now. "
i just went to cobb stage 1 w/ a cobb intake, borla catback and hks bov. i took a log but it was on a slight incline and i only went from 2.5-4.5 rpm. bottom was up a steep hill. any help would be cool. im gonna probly get better logs soon, cause i think these two are effed up, but anyway...
https://docs.google.com/spreadsheet/...1E&usp=sharing
and
https://docs.google.com/spreadsheet/...Gc&usp=sharing
thekamikaze kid is offline
post #2 of 26 Old 09-17-2013, 06:09 PM
boo-key's Avatar
Sorry to hate but, you gotta get rid of that bov! Hks is the worst one!
pzr2874, BLAZE2099 and NeverSummer like this.
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
post #3 of 26 Old 09-17-2013, 06:49 PM
At no point in time did you build over Wastegate PSI. You have to have a preturbo leak or a wastegate issue on your turbo. Plus, your car is pulling timing also...
Then again...you weren't in the prime of the boost range either. But, you're small turbo should've been spooled up though...by 4.5k rpms.
post #4 of 26 Old 09-17-2013, 06:56 PM Thread Starter
what do u mean by timing? oh and like i said the log was effed up i dont think i was at full throttle for most of the log, there was a slight incline, it was only a 2.5-4.5 pull.
oh and yah i noticed my boost was pretty low. in the stage one map notes it said i was supposed to be at ~15psi
post #5 of 26 Old 09-17-2013, 06:57 PM
You lose timing at some points and are experiencing fine knock...but, if you didn't go full throttle. Then its a skewed pull.
thekamikaze kid likes this.
post #6 of 26 Old 09-17-2013, 07:05 PM Thread Starter
thanks for the help. i believe there is a throttle position percentage value im def not at fulll throttle. ill try to get a better log up later in the week.
post #7 of 26 Old 09-17-2013, 07:40 PM
Wonder why your not hitting full boost?
Due to not going WOT you think? You should hit a bit before that.
post #8 of 26 Old 09-17-2013, 07:56 PM Thread Starter
i was pretty sure i had the pedal to the floor for at least a few seconds, i guess it didnt show up...ill try again soon. the second log was def not wot tho, i was nt sure if u could still use the log if going uphill.
post #9 of 26 Old 09-17-2013, 09:22 PM
No....your throttle position sensor never went over 40ish%. That's not WOT. In either pull...if that's where you're experiencing performance issues. Then its the BOV...partial boost/throttle and issues is due to a leaky BOV more than likely.
boo-key and BLAZE2099 like this.
post #10 of 26 Old 09-18-2013, 04:06 PM Thread Starter
I dont think that hte throttle sensor reading is completely accurate. i think that it isnt measuring the pedal to floor %, its measuring the actual throttle body. im pretty sure i was at least close to the floor with the pedal. but def more than 40%, thats way off.
i emailed cobb and told them what my situation was WITHOUT the log and they said It could potentially be an issue with the wastegate not actuating properly, or i could be overboosting and that could be causing a fuel cut. this only happens when in early gears and up hills tho. is there any evidence in these logs b4 i do a new log that would support this?
post #11 of 26 Old 09-18-2013, 04:25 PM
boo-key's Avatar
You would know if you had fuel cut. It is somewhat of a violent and scary thing the first time it happens and your not expecting it.
Plus you would probably get a code for overboosting and the cruise light would flash.
To test your wastegate acuator you can put a hand pump to the nipple on it and watch it to see if its opening properly and fully at the correct psi .
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
post #12 of 26 Old 09-18-2013, 06:19 PM Thread Starter
After reviewing my crappy log, Cobb said my dam was low due to it learning the new flash or something was "unhappy" under the hood. But yeah something is effing up my timing, hopefully that it is just learning issue, but I think that the "hill" issue is another issue altogether, not sure tho.
post #13 of 26 Old 09-18-2013, 06:27 PM Thread Starter
To test your wastegate acuatior you can put a hand pump to the nipple on it and watch it to see if its opening properly and fully at the correct psi .
Not mechanically inclined to do that but I will def further inquire about that
post #14 of 26 Old 09-18-2013, 07:34 PM
Bet ya ten bucks your car runs better with a stock BPV or a well built one
pzr2874 and boo-key like this.
post #15 of 26 Old 09-18-2013, 07:41 PM
06_hawk_eye's Avatar
06_hawk_eye is an unknown
I had a turbo xs hybrid one on mine and I was like it doesn't affect it that much. Took it off and it was day and night . Been running the stock one ever since. Look on Craigslist for a stock one man or I'm sure someone on here had a sticker laying around.
Sent from AutoGuide.com App
boo-key likes this.
06_hawk_eye is offline
