Help me see if my engine is knocking - Subaru WRX Forum
post #1 of 42 Old 09-12-2011, 07:23 PM Thread Starter
Wrxsubie2008 is more helpful than not
Hi everyone I would like some help on determining if my engine is knocking. I am new to subaru and to tuning. I bought a tatrix cable to be able to log the car and in the future to do or get some tuning done. I am very interested in tuning but it is not something that i can rush into learning on my own especially when i dont know anyone that does it that can teach me. But can someone please take a look at my log to help me see if the engine is knocking. I understand i may be logging to much so if i need to log less or log something more specific please let me know so that i can go log again and post it up here for someone to help me.
PS: In order for me to upload onto here it says i must have it in a txt format but those are a PITA to read so if you would like to be able to view it in excel change the file from .txt to .csv (Im sure all you tuners already know this but just putting it here incase)
Thanks everyone.
Wrxsubie2008 is offline
post #2 of 42 Old 09-12-2011, 07:50 PM
Try doing a log in 3rd gear from 2000-6000. That will make things easier to read rather than sorting through a bunch of useless stuff.Also here is a list of things to log:
HERE
post #3 of 42 Old 09-12-2011, 08:46 PM Thread Starter
HERE
Thank you so much I will log that tomorrow and post it up.
post #4 of 42 Old 09-12-2011, 09:17 PM
No problem that's why we are here...Plus I remember back when I first started and hardly anyone would explain things to me...It sucked...
post #5 of 42 Old 09-12-2011, 10:33 PM Thread Starter
Ya its tough learning but I wanna be able to do it so I will learn and read and get as much help from whoever I can.
Anyways I said I would do logs tomorrow but took a quick run and took them now i did 2 logs from 2000 to 6000 and then one log i had to cut short but will attached it anyways.
There may be a few things that did not need logged such as engine load i was not sure what one was wanted from that link that you sent me.
Here ya go thank you so much again
post #6 of 42 Old 09-13-2011, 05:35 AM
I can't even open those.
No Excel handy ? Anyone care to fix?
post #7 of 42 Old 09-13-2011, 05:39 AM Thread Starter
You should be able to open them I uploaded them as .txt since the site does not support .csv files
post #8 of 42 Old 09-13-2011, 05:56 AM
If you convert them to excel, I can help.... May not be ALL the help you need... But everyone likes looking at logs here...
post #9 of 42 Old 09-13-2011, 08:15 AM
Code:
Time	RPM	Timing	PSI	WGDC	TOA	MAF	Load	FBKC	FLKC	IAM
0	1755	36	3.82	24.71	15.29	22.24	0.73	0	0	1
340	1816	26	5.26	43.14	25.49	33.77	0.97	0	0	1
691	1900	21	5.8	53.73	30.2	37.01	1.12	0	0	1
1031	1992	18	10.09	53.73	100	42.46	1.25	0	0	1
1382	2084	17	9.46	53.73	100	47.11	1.33	0	0	1
1712	2150	19	8.66	53.73	100	50.42	1.41	0	0	1
2052	2267	17.5	7.75	53.33	100	56.7	1.51	0	0	1
2383	2368	15.5	6.4	53.33	100	65.92	1.66	0	0	1
2733	2493	13	4.9	53.33	100	76.2	1.82	0	0	1
3064	2620	12.5	3.23	52.55	100	88.95	2.01	0	0	1
3404	2750	10.5	1.07	47.45	100	101.62	2.2	0	0	1
3745	2890	11.5	0.08	46.27	100	108.9	2.29	0	0	1
4085	3014	12.5	0.27	46.27	100	112.88	2.26	0	0	1
4416	3189	13	0.43	46.67	100	119.07	2.26	0	0	1
4756	3312	13.5	0.13	47.06	100	126.6	2.3	0	0	1
5087	3468	14.5	0.04	47.84	100	130.71	2.3	0	0	1
5427	3599	16	0.02	48.63	100	137.17	2.32	0	0	1
5768	3752	16	0.06	49.41	100	142.48	2.31	0	0	1
6108	3870	17	0.16	50.59	100	144.37	2.29	0	0	1
6449	3996	17	0.17	51.76	100	154.58	2.31	0	0	1
6789	4146	16.5	0.03	51.37	100	160.02	2.34	0	0	1
7130	4261	17	0.2	51.37	100	166.14	2.37	0	0	1
7470	4397	17	0.23	50.98	100	171.72	2.37	0	0	1
7811	4503	14	0.02	50.2	100	177.92	2.38	0	0	1
8151	4589	14.5	-0.1	49.41	100	181.56	2.35	0	0	1
8492	4704	15.5	-0.04	49.02	100	180.1	2.32	0	0	1
8832	4838	16	0.05	48.24	100	184.11	2.29	0	0	1
9173	4912	17	-0.02	47.45	100	187.44	2.28	0	0	1
9503	5047	17.5	0.1	47.45	100	188.2	2.25	0	0	1
9854	5107	18.5	0.27	49.02	100	189.76	2.23	0	0	1
10204	5214	18.5	0.3	49.41	100	194.44	2.22	0	0	1
10535	5332	18.5	0.33	49.8	100	196.78	2.21	0	0	1
10885	5432	18.5	0.37	50.2	100	194.83	2.18	0	0	1
11216	5478	18.5	0.36	50.2	100	197.56	2.15	0	0	1
11556	5556	18.5	0.37	50.59	100	197.56	2.13	0	0	1
11897	5662	18.5	0.33	47.45	100	199.9	2.13	0	0	1
12237	5748	19	0.13	39.22	100	198.73	2.08	0	0	1
12578	5791	19.5	0.21	34.51	100	201.46	2.07	0	0	1
12918	5899	20	0.34	31.37	100	197.95	2.02	0	0	1
13259	5921	20.5	0.41	24.71	100	197.95	2	0	0	1
13609	6034	21.5	0.34	21.96	100	200.29	1.98	0	0	1
13950	6106	22.5	0.31	21.96	100	201.07	1.97	0	0	1
14300	6084	26.5	-4.1	0	21.57	79.07	0.95	0	0	1
No knock, the other logs are just as clean.
Ran a quick log for you on Airboy as well since you appear to have a stock 2008 WRX. This is based on your elevation where you are, yesterday's weather data, and using 2008 WRX weight and 3rd gear data. If you used a different gear then this dyno is wrong. Power is at the wheels, and for airboy this isn't a bad number for a stock 2008.
post #10 of 42 Old 09-13-2011, 08:42 AM Thread Starter
[/QUOTE]
Wow thank you so much I appreciate it alot and I have never heard of airboy but seems pretty cool. Thanks again.
post #11 of 42 Old 09-13-2011, 08:43 AM Thread Starter
Prz if you want to look at the logs in excel download the files I uploaded then change the file extension from .txt to .csv .csv will open in excel
post #12 of 42 Old 09-13-2011, 09:02 AM
Chris knows his junk.... From what he did, I can see everything now.
Only thing I see interesting is the PSI column, what is that logged in ? It's not KPA or BAR... and not PSI.
WTH is it? lol
post #13 of 42 Old 09-13-2011, 09:22 AM Thread Starter
WTH is it? lol
The log says boost error* (psi)
post #14 of 42 Old 09-13-2011, 09:26 AM
Makes sense for the correction.
What are you logging with ?
Nevermind... OS
Go get a tune with a 3port BCS.
post #15 of 42 Old 09-13-2011, 09:29 AM Thread Starter
Lol answering your own question.
I would like to thank everyone for their help again. Everyone on this site is friendly and helpful people on nasioc just say well why are you logging if you don't know what your doing. But it's whatever gotta learn some way some how
Thanks
