-   -   Help me see if my engine is knocking (http://www.wrxtuners.com/forums/f70/help-me-see-if-my-engine-knocking-31324/)
Wrxsubie2008 09-12-2011 07:23 PM
1 Attachment(s)
Hi everyone I would like some help on determining if my engine is knocking. I am new to subaru and to tuning. I bought a tatrix cable to be able to log the car and in the future to do or get some tuning done. I am very interested in tuning but it is not something that i can rush into learning on my own especially when i dont know anyone that does it that can teach me. But can someone please take a look at my log to help me see if the engine is knocking. I understand i may be logging to much so if i need to log less or log something more specific please let me know so that i can go log again and post it up here for someone to help me.
PS: In order for me to upload onto here it says i must have it in a txt format but those are a PITA to read so if you would like to be able to view it in excel change the file from .txt to .csv (Im sure all you tuners already know this but just putting it here incase)
Thanks everyone.
psinuse 09-12-2011 07:50 PM
Try doing a log in 3rd gear from 2000-6000. That will make things easier to read rather than sorting through a bunch of useless stuff.Also here is a list of things to log:
[URL="http://www.romraider.com/Documentation/RomRaiderFAQ#toc63"]HERE[/URL]
Wrxsubie2008 09-12-2011 08:46 PM
[quote=psinuse;267660]Try doing a log in 3rd gear from 2000-6000. That will make things easier to read rather than sorting through a bunch of useless stuff.Also here is a list of things to log:
[URL="http://www.romraider.com/Documentation/RomRaiderFAQ#toc63"]HERE[/URL][/quote]
Thank you so much I will log that tomorrow and post it up.
psinuse 09-12-2011 09:17 PM
No problem that's why we are here...Plus I remember back when I first started and hardly anyone would explain things to me...It sucked...
Wrxsubie2008 09-12-2011 10:33 PM
3 Attachment(s)
[quote=psinuse;267662]No problem that's why we are here...Plus I remember back when I first started and hardly anyone would explain things to me...It sucked...[/quote]
Ya its tough learning but I wanna be able to do it so I will learn and read and get as much help from whoever I can.
Anyways I said I would do logs tomorrow but took a quick run and took them now i did 2 logs from 2000 to 6000 and then one log i had to cut short but will attached it anyways.
There may be a few things that did not need logged such as engine load i was not sure what one was wanted from that link that you sent me.
Here ya go thank you so much again
pzr2874 09-13-2011 05:35 AM
I can't even open those.
No Excel handy ? Anyone care to fix?
Wrxsubie2008 09-13-2011 05:39 AM
You should be able to open them I uploaded them as .txt since the site does not support .csv files
pzr2874 09-13-2011 05:56 AM
If you convert them to excel, I can help.... May not be ALL the help you need... But everyone likes looking at logs here...
RcrsWetDream 09-13-2011 08:15 AM
1 Attachment(s)
[code]Time RPM Timing PSI WGDC TOA MAF Load FBKC FLKC IAM
0 1755 36 3.82 24.71 15.29 22.24 0.73 0 0 1
340 1816 26 5.26 43.14 25.49 33.77 0.97 0 0 1
691 1900 21 5.8 53.73 30.2 37.01 1.12 0 0 1
1031 1992 18 10.09 53.73 100 42.46 1.25 0 0 1
1382 2084 17 9.46 53.73 100 47.11 1.33 0 0 1
1712 2150 19 8.66 53.73 100 50.42 1.41 0 0 1
2052 2267 17.5 7.75 53.33 100 56.7 1.51 0 0 1
2383 2368 15.5 6.4 53.33 100 65.92 1.66 0 0 1
2733 2493 13 4.9 53.33 100 76.2 1.82 0 0 1
3064 2620 12.5 3.23 52.55 100 88.95 2.01 0 0 1
3404 2750 10.5 1.07 47.45 100 101.62 2.2 0 0 1
3745 2890 11.5 0.08 46.27 100 108.9 2.29 0 0 1
4085 3014 12.5 0.27 46.27 100 112.88 2.26 0 0 1
4416 3189 13 0.43 46.67 100 119.07 2.26 0 0 1
4756 3312 13.5 0.13 47.06 100 126.6 2.3 0 0 1
5087 3468 14.5 0.04 47.84 100 130.71 2.3 0 0 1
5427 3599 16 0.02 48.63 100 137.17 2.32 0 0 1
5768 3752 16 0.06 49.41 100 142.48 2.31 0 0 1
6108 3870 17 0.16 50.59 100 144.37 2.29 0 0 1
6449 3996 17 0.17 51.76 100 154.58 2.31 0 0 1
6789 4146 16.5 0.03 51.37 100 160.02 2.34 0 0 1
7130 4261 17 0.2 51.37 100 166.14 2.37 0 0 1
7470 4397 17 0.23 50.98 100 171.72 2.37 0 0 1
7811 4503 14 0.02 50.2 100 177.92 2.38 0 0 1
8151 4589 14.5 -0.1 49.41 100 181.56 2.35 0 0 1
8492 4704 15.5 -0.04 49.02 100 180.1 2.32 0 0 1
8832 4838 16 0.05 48.24 100 184.11 2.29 0 0 1
9173 4912 17 -0.02 47.45 100 187.44 2.28 0 0 1
9503 5047 17.5 0.1 47.45 100 188.2 2.25 0 0 1
9854 5107 18.5 0.27 49.02 100 189.76 2.23 0 0 1
10204 5214 18.5 0.3 49.41 100 194.44 2.22 0 0 1
10535 5332 18.5 0.33 49.8 100 196.78 2.21 0 0 1
10885 5432 18.5 0.37 50.2 100 194.83 2.18 0 0 1
11216 5478 18.5 0.36 50.2 100 197.56 2.15 0 0 1
11556 5556 18.5 0.37 50.59 100 197.56 2.13 0 0 1
11897 5662 18.5 0.33 47.45 100 199.9 2.13 0 0 1
12237 5748 19 0.13 39.22 100 198.73 2.08 0 0 1
12578 5791 19.5 0.21 34.51 100 201.46 2.07 0 0 1
12918 5899 20 0.34 31.37 100 197.95 2.02 0 0 1
13259 5921 20.5 0.41 24.71 100 197.95 2 0 0 1
13609 6034 21.5 0.34 21.96 100 200.29 1.98 0 0 1
13950 6106 22.5 0.31 21.96 100 201.07 1.97 0 0 1
14300 6084 26.5 -4.1 0 21.57 79.07 0.95 0 0 1
[/code]
No knock, the other logs are just as clean.
Ran a quick log for you on Airboy as well since you appear to have a stock 2008 WRX. This is based on your elevation where you are, yesterday's weather data, and using 2008 WRX weight and 3rd gear data. If you used a different gear then this dyno is wrong. Power is at the wheels, and for airboy this isn't a bad number for a stock 2008.
[IMG]http://img.photobucket.com/albums/v253/weeksifer/Log-1.jpg[/IMG]
Wrxsubie2008 09-13-2011 08:42 AM
[IMG]http://img.photobucket.com/albums/v253/weeksifer/Log-1.jpg[/IMG][/QUOTE]
Wow thank you so much I appreciate it alot and I have never heard of airboy but seems pretty cool. Thanks again.
Wrxsubie2008 09-13-2011 08:43 AM
Prz if you want to look at the logs in excel download the files I uploaded then change the file extension from .txt to .csv .csv will open in excel
pzr2874 09-13-2011 09:02 AM
Chris knows his junk.... From what he did, I can see everything now.
Only thing I see interesting is the PSI column, what is that logged in ? It's not KPA or BAR... and not PSI.
WTH is it? lol
Wrxsubie2008 09-13-2011 09:22 AM
[quote=pzr2874;267692]Chris knows his junk.... From what he did, I can see everything now.
WTH is it? lol[/quote]
The log says boost error* (psi)
pzr2874 09-13-2011 09:26 AM
Makes sense for the correction.
What are you logging with ?
Nevermind... OS
Go get a tune with a 3port BCS.
Wrxsubie2008 09-13-2011 09:29 AM
Lol answering your own question.
I would like to thank everyone for their help again. Everyone on this site is friendly and helpful people on nasioc just say well why are you logging if you don't know what your doing. But it's whatever gotta learn some way some how
Thanks
