help me fix this cel so i cn get TUNED!!!! - Subaru WRX Forum
post #1 of 9 Old 06-30-2011, 11:16 AM Thread Starter
i have a 08 sti with a 20g 850cc injectors aem intake, catless exhaust etc. my problem keeps happening where i keep getting a p0303 misfire cylinder 3, traction control comes on, and defaults to s mode. now i have swapped coils it has brand new plus and injectors in it, and has good compression. it happen to me twice after making a hard turn and boosting right out of it, all of the lights came on at the same time. i almost know its not in cylinder 3 idk is it possible that the traction control light is some how causing the CEL and the cylinder to misfire, maybe fuel cut off, it only cyl 3 that it keeps happening too?? please help because i really need a tune!!!
MaxTegRoom is offline
post #2 of 9 Old 06-30-2011, 12:58 PM Thread Starter
anybody know what this could be. does the p0303 turn default the S mode and traction control. or do i have a problem with my traction control that is kicking the p0303
post #3 of 9 Old 06-30-2011, 01:18 PM
phatron
Guest
Posts: n/a
Your misfire CEL is most likely from not being tuned.....
Are you really running all that stuff untuned?
post #4 of 9 Old 06-30-2011, 03:52 PM Thread Starter
no i have a tune i have to get it retuned to smooth out the part throttle.. i dont know why my cel p0303 and trac light and s mode all came on at the same time...
post #5 of 9 Old 06-30-2011, 07:37 PM
Its safety for the car. If you didnt revert to limp or safe mode and kept letting it misfire in the cylinder you can go ahead and count on rebuilding your engine. Get the tune and talk to your tuner about it as they could/should be able to see the car in person and help more.
post #6 of 9 Old 07-01-2011, 09:26 PM
Who is your tuner? I'd be shocked if they couldn't fix the problem before it got tuned. I believe if the CEL comes up 3 times the ECU will freeze frame "snap shot" the exact thing that is causing the CEL. Making the tuner's job a lot easier to troubleshoot. That is what my tuner said when I was have a CEL last year. I can't remember what he was using some kind of scan tool for the laptop.
post #7 of 9 Old 07-05-2011, 06:56 PM
phatron
Guest
Posts: n/a
tactrix cable + learning view.
learning view gives you the snapshot of the AF Learning, CEL codes, and knock learning table
post #8 of 9 Old 07-05-2011, 07:16 PM
Sweet thanks for the assist.
post #9 of 9 Old 07-06-2011, 12:20 AM
phatron
Guest
Posts: n/a
no prob
