hi i have attached 2 files , 1 is the learning view and another is my ecu flash (openecu.org • View topic - help!!!). anyone can help me? anyone can explain what causes the temporary DTC and memorised DTC? thanks so much! and anyone can tell me what causes each DTC? tks!
your car is running too lean causing knock, a low 02 sensor input and because it's leaner its running hot causing the high Exhaust Gas Temperature circuit
