Help!!! - Page 2 - Subaru WRX Forum
post #16 of 25 Old 07-28-2012, 08:51 PM Thread Starter
huschkem3's Avatar
huschkem3 is an unknown
the datalog i attached to my previous post is w/ AP stage 2 AEM ACN91.
and yes, i've learned my vivid racing lesson. i had a friend who worked in sales there... only reason i ever went.
paul h - SSFD (super slow 4-door)
huschkem3 is offline
post #17 of 25 Old 07-28-2012, 10:24 PM
Adjust your BOV. It's leaking...
post #18 of 25 Old 07-29-2012, 12:52 AM Thread Starter
huschkem3's Avatar
could that be the problem?
post #19 of 25 Old 07-29-2012, 12:58 AM Thread Starter
huschkem3's Avatar
should i just replace it? what would you recommend?
post #20 of 25 Old 07-29-2012, 01:52 AM Thread Starter
huschkem3's Avatar
i will check everything on it for pressure and tightness and if the problem persists i will adjust the valve itself.
post #21 of 25 Old 07-29-2012, 05:53 AM
Does your car have the restrictor pills in it? Your wastegate duty cycles look off.
post #22 of 25 Old 07-30-2012, 05:54 AM
Put the stock BPV back on to rule it out.
post #23 of 25 Old 07-31-2012, 12:36 AM Thread Starter
huschkem3's Avatar
i'm not sure what it was exactly but i disassembled my BOV, cleaned it, reinstalled it, checked all of my hoses and it was still messed up. i was still cutting fuel and throwing a code for overboosting. i gave up altogether and reflashed the OS tune i had on my AP and listed the AP on eBay to get some extra cash for repairs. i drove the car to work and it still sucked. THEN FOR SOME REASON IT WAS PERFECT ON MY DRIVE HOME!!! i honestly can not explain it. it's like the car fixed itself.
thanks for all of the help guys.
i'll repost if the problems come back.
post #24 of 25 Old 07-31-2012, 05:19 AM
Have you recently filled the car with gas?
post #25 of 25 Old 07-31-2012, 05:36 AM
Maybe the file was bad on the map OR your ECU is taking a $hit
