gopoint bt1 - Subaru WRX Forum
post #1 of 4 Old 05-29-2013, 09:32 AM Thread Starter
pjkatz04's Avatar
pjkatz04 is an unknown
gopoint bt1
located here GoPoint BT1 | GoPoint
bought this awhile ago, in order to monitor ecu. anyone else get it? mine doesn't sit properly in the odb port, and therefore disconnects and reconnects intermittently, causing a dtc error. annoying. jw if anyone else has this problem
12 wrx
pjkatz04 is offline
post #2 of 4 Old 06-07-2013, 11:53 AM
most folks use a Cobb AP for an ODBII monitor if they have one at all.
post #3 of 4 Old 06-07-2013, 01:46 PM
Vendor
PROImportTuners's Avatar
PROImportTuners is more helpful than not
Be careful when connecting those cheaper style Bluetooth OBDII Dongles. The tolerances on them are usually not as precise as OEM and the pins inside the OBD connector can bend or break if misaligned.
The other thing to be aware of is that Pin 16 on the OBD connector is usually "Hot" at all times so even if the ignition is "Off" the device may still be draining battery power if plugged in. (I know alot of people leave devices like this plugged in all the time and don't know that they are using power even when the car is off).
We are having a sale on COBB Accessport if you decide to upgrade: MEGA Sale on COBB Accessport for WRX and STI!
PRO Import Tuners
PROImportTuners is offline
post #4 of 4 Old 06-07-2013, 02:19 PM Thread Starter
pjkatz04's Avatar
Yea I'll go ap as soon as I can save enough. I want stage 1 anyway.
pjkatz04 is offline
