Get rid of CEL with UTEC - Subaru WRX Forum
post #1 of 8 Old 06-02-2003, 12:21 PM Thread Starter
SWRX0983 is an unknown
Send a message via AIM to SWRX0983
does any one know step by step how to get rid of the cel when you install a txs uppipe, and turbo back exhaust with the catless race pipe? How do you change the codes and all that?
SWRX0983 is offline
post #2 of 8 Old 06-03-2003, 08:47 AM
Kobiyashi's Avatar
Kobiyashi is more helpful than not
It's under special paramenters in the map edit mode.
-Kobi
The 2 most repeated things I have to say are now in my sig to save typing an extra 5,000 characters a day:
*** DO NOT upgrade your intake until you upgrade your injectors ***
*** DO NOT raise boost until that ugly cat in your uppipe is gone ***
~~ Need any more help? AIM me OR call [# in profile] ~~~
Kobiyashi is offline
post #3 of 8 Old 06-03-2003, 08:51 AM Thread Starter
Thanks
SWRX0983 is offline
post #4 of 8 Old 06-03-2003, 09:15 AM
Kobiyashi's Avatar
No problem, just remember it removes any CEL and you need to check it often to make sure no other reason codes are showing.
-Kobi
post #5 of 8 Old 06-03-2003, 09:22 AM
Kobiyashi's Avatar
-Kobi
post #6 of 8 Old 06-04-2003, 01:51 AM
SloRice's Avatar
SloRice is an unknown
Send a message via AIM to SloRice
Kobi,
I thought I read somewhere that the UTEC can block certain CEL's (i.e. faulty cats b/c there are no cats) but still have the CEL come on if something else goes wrong???
~Tim
SloRice is offline
post #7 of 8 Old 06-04-2003, 06:37 AM
fc735's Avatar
the code stays in the factory pcm, but the utec interrrupts the signal to the CEL in the dash. the code/freeze frame data stays in memory, and can be accessed through the obdII diag port...with a scanner. if i remember right, the utec cuts the cel off completely, or flashes it when knock is detected, or works normal.....one of the three. dont think it blocks certain codes, either all or none.....
JOEY
fc735 is offline
post #8 of 8 Old 06-04-2003, 08:32 AM
Kobiyashi's Avatar
It doesn't block certain codes, it blocks them all. Only flashes with Engine Det (Knock). They are working on a new Code that will only eliminate certain OBDII codes.
-Kobi
