Gauges - Page 2 - Subaru WRX Forum
 8Likes
post #16 of 29 Old 12-10-2013, 03:49 PM
They put a Wideband on the muffler tip to do dyno tunes.
post #17 of 29 Old 12-10-2013, 04:33 PM
My tuner runs a cable thru the trunk and to the muffler during the road tune portion.
post #18 of 29 Old 12-10-2013, 04:42 PM
Or that for a road tune....
post #19 of 29 Old 12-10-2013, 05:05 PM Thread Starter
Premium Member
Nathan21's Avatar
Nathan21 is an unknown
so not necessary to have gauges for a protune?
Nathan
2011 WRX Premium
2012 Fozzy
1979 C3
Anti-BOV Gang!
Nathan21 is offline
post #20 of 29 Old 12-10-2013, 05:12 PM
Not unless your tuner requires it....
post #21 of 29 Old 12-10-2013, 05:35 PM Thread Starter
Premium Member
Nathan21's Avatar
I will talk to them tomorrow
Nathan
2011 WRX Premium
2012 Fozzy
1979 C3
Anti-BOV Gang!
Nathan21 is offline
post #22 of 29 Old 12-10-2013, 07:33 PM
Vendor
PROImportTuners's Avatar
PROImportTuners is more helpful than not
^Yeah some don't require gauges.
The most important info for most tuners is A/F ratio. Some have their own wideband setups, so they don't require you to have your own.
It doesn't hurt of course, and extra gauges can help you spot trouble early to help avoid damage. (If you see your A/F swing lean or your Oil pressure drop for example you can let off the throttle).
Most common gauges people get are:
Wideband A/F
Boost pressure
Oil Temp
Oil Pressure
Water Temp
If you like the "Opening Ceremony" type (Think Defi or stock STI ceremony) then check out "STRI" gauges:
Import STRI DSD SLM II Smoke Lens Gauges at PRO Import Tuners
Smoke lens, opening ceremony, fully digital, lab grade sensors, ect...
The AEM digital gauges are actually really cool too:
Import AEM Analog Face Digital Gauges at PRO Import Tuners
They have interchangeable lens faces and LED color back lighting choices, so you can customize them to match your audio deck, stock gauges or whatever.
You can also use the pressure and temp gauges for different uses by swapping out the face and tapping into the other source. (The Oil temp gauge could also be used for Water temp ect...)
PRO Import Tuners
PROImportTuners is offline
post #23 of 29 Old 12-10-2013, 07:47 PM
EGT (exhaust temperature) has been helpful for me because there have been a few times trying to keep up with other vehicles at high speeds where I've come close to the melting point of aluminum. Scary. This is at WOT and the boost pegged. Problem is you have to either weld in the probe or thread a hole for the probe in your exhaust manifold.
I'm also partial to Defi, but that's because they were the ones that supplied our cluster. I don't know if this is still true for current years.
Proof our gauges are made by Defi
post #24 of 29 Old 12-10-2013, 07:55 PM Thread Starter
Premium Member
Nathan21's Avatar
Vew, like some of the guys said in the start of this thread, I think some of the brains on the forum should make a sticky for this!
Nathan
2011 WRX Premium
2012 Fozzy
1979 C3
Anti-BOV Gang!
Nathan21 is offline
post #25 of 29 Old 12-10-2013, 10:57 PM
Laxx1991 is an unknown
I'm getting the SMY gauge cluster. its pretty clean looking, only down fall it only hold 2 gauges. I'm
def getting a A/F gauge (AEM UEGO) and for the other side i was thinking maybe a boost gauge most likely AEM UEGO to match the other side.
Laxx1991 is offline
post #26 of 29 Old 12-11-2013, 10:50 AM
Although the thread contains helpful information, it doesn't really contain enough organized technical information to warrant a sticky. It's heavily weighed toward brands and cosmetic opinion which can change very quickly. Like Haw1es said, if someone were to re-write it in a clear concise manner sticking to technical data preferably with sources (unless it was a known expert), then perhaps. Personally, I do not know enough to write one. I have the gauges I have because it was personal needs/wants.
post #27 of 29 Old 12-11-2013, 11:39 AM
Haw1es's Avatar
Haw1es is more helpful than not
Yea, I figured this thread wouldn't be stickied. If I had the knowledge I would def write one but I can't guarantee itd be right FOL.
Along with gauges, would it make sense to get a down pipe with an additional O2 bung already welded into it? I know rallysportdirect has an invidea one that has that. Would paying a little more to have that in make it easier in the long run to install an a/f gauge?
Shane
2010 WRX
2014 F150
Haw1es is offline
post #28 of 29 Old 12-11-2013, 12:04 PM
Premium Member
arewmors's Avatar
Cobb DP comes with an extra bung for a gauge. I currently have the Cobb DP.
Andy - 12 WRB WRX
Tuned by Innovative Tuning
294 AWHP / 311 TQ
arewmors is offline
post #29 of 29 Old 12-11-2013, 02:16 PM Thread Starter
Premium Member
Nathan21's Avatar
I have the cobb dp as well, and they have a blocked off whole on the top of the dp that can be removed to have the bung in there
Nathan
2011 WRX Premium
2012 Fozzy
1979 C3
Anti-BOV Gang!
Nathan21 is offline
