Front mount or Top mount intercooer - Subaru WRX Forum
post #1 of 10 Old 01-01-2008, 04:26 PM Thread Starter
nicolas316 is an unknown
its time i change upgrade my intercooler but i dont know what to put yet. im thiniking of the top mount intercooler, is it good? which brand, and is it better than front mount? thanks. nicolas
nicolas316 is offline
post #2 of 10 Old 01-01-2008, 05:03 PM
What turbo, other mods?
post #3 of 10 Old 01-01-2008, 07:43 PM
Top mount:
Less lag
Easy to install
Keep bumper beam
Front mount:
Less heat soak
Possibly much bigger than top mount
You don't have to take it off for every install
WReXd is offline
post #4 of 10 Old 01-02-2008, 01:02 AM
matters on the size of the turbo and your hp vs lag feelings.
Small turbos (like the stocker) really don't see any benefit from the front mount and it will add a fair bit of lag.
Big turbos really demand cooling that a TMIC can't provide to unleash their full power.
What turbo do you have in mind? If you say stock, a FMIC is a really bad (and expensive) idea...
post #5 of 10 Old 01-02-2008, 07:38 AM
Longshot's Avatar
+1 to what mosc said. I'd base it more on what your future turbo ugrade may be. For me with the 2.0L I'll be heading the direction of an STi top mount with an evo3 16G. If I had a 2.5L I'd look into a TD06 20G with maybe a front mount. Either way I'd base it on what type of turbo you plan on, and of course if you stay stock a TMIC will be your best option.
DTRacing Tuned
Longshot is offline
post #6 of 10 Old 01-02-2008, 01:46 PM
hey longshot, just a friendly word here... the STi top mount is bigger than your stocker but not by much. I think it's about 40% larger? The 06-07 WRX's actually have a smaller intercooler than the 02-05s. Anyway, A good aftermarket unit is going to be 2.5x your stocker. An E3-16G is a nice medium turbo that works well with a TMIC but it will limit on an STi TMIC. I'd be looking at Perrin or APS or even SSAC if you want something cheap.
post #7 of 10 Old 01-02-2008, 01:54 PM
Longshot's Avatar
Thanks mosc I did not know that. I'm not in the market quite yet, but I'll keep that in mind for when I am.
DTRacing Tuned
Longshot is offline
post #8 of 10 Old 01-03-2008, 06:19 PM Thread Starter
for know im running a stock turbo, i have 75mm catless exhaust system with em. later id probably install a bigger turbo. if i put a tmic now id have to change it again whe i upgrade my turbo??
post #9 of 10 Old 01-04-2008, 12:50 AM
Not necessarily. Especially if you go with a TMIC. It depends on what numbers you are planning on or trying to make on the car. You will probably be limited to ~400AWHP with a top mount. Those are just numbers I have seen and read with a top mount.
post #10 of 10 Old 01-04-2008, 12:25 PM
I think shoaf's torque curve with that 400whp TMIC setup showed it had longsince become limiting. I'd think it would be in the 300-350whp range where you top out the largest of TMICs on a WRX.
