flat foot shifting rpm - Subaru WRX Forum
post #1 of 5 Old 07-24-2008, 03:08 PM Thread Starter
zmanoside's Avatar
zmanoside is a helpful contributing member
Hey guys. Going to the track tonight to get into the 12's for the 1st time hopefully in the newly stg 2 STi. I just reflashed the ecu with cobbs ap w/ launch control and flat foot shifting enabled map. I just set the launch control at 5,000 rpm and the flat foot shifting at 4,800 rpm. I know I should be good with the 5k launch control, but anyone have suggestions for the rpm settings for the flat foot shifting?? The first run will be without launch control and then I'm gonna try it out on the second run. Any suggestions are appreciated. Z
12.7 @ 109
zmanoside is offline
post #2 of 5 Old 07-24-2008, 06:30 PM
Longshot's Avatar
you plan on shifting around 4800 in all gears? You need to rev higher than that. I'd set it to 6200rpm.
DTRacing Tuned
Longshot is offline
post #3 of 5 Old 07-24-2008, 08:59 PM Thread Starter
zmanoside's Avatar
Dudes I didnt even use FF shifting. I planed on doing the 1st run without using anything, which I did and ran a FN 13.4!!! 2 weeks ago stg1 I ran 13.2's...It was just too damn hot and humid tonight, the car was running really slow. 13.4 was my best time tonight too
TOO DAMN HOT!!! Waste of my time. I did use the LC once, and I had better 60' times not using it so I said F it.
12.7 @ 109
post #4 of 5 Old 07-25-2008, 12:37 AM
For flat foot shifting, its all about where your power is. You need to know or find out where the torque is highest between that gear and the upcoming on and set it for that area basically.
post #5 of 5 Old 08-27-2008, 11:12 AM
blackonblack is an unknown
yeah when i set lc to 5,900 or 6,100 it doesnt feel like my clutch clamps down hard.. if i'm manualy playing on the throtle.. but i have a bad right foot so... lc i'd have to do
also flat shift at 5,600 4 5ish but i do have RA gearing
blackonblack is offline
