flashed stage 1 boost question - Subaru WRX Forum
post #1 of 4 Old 11-16-2007, 05:34 PM Thread Starter
Wilks132's Avatar
Wilks132 is an unknown
I just flashed stage 1 91 octane. In 5th gear on the highway I hit about 1.02-1.03 on my spt boost gauge flooring it. The map notes call for 13.5 psi. Well 1.02 calculated is 14.8 psi . Am I over boosting?
Wilks132 is offline
post #2 of 4 Old 11-16-2007, 05:57 PM
IH8PVMNT's Avatar
IH8PVMNT is an unknown
check it out 2nd post 14.5-14.9 sounds about right
Stock boost...? 2006 wrx
IH8PVMNT is offline
post #3 of 4 Old 11-16-2007, 11:35 PM Thread Starter
Wilks132's Avatar
am i converting the numbers tight?? The needle of the boost gauge goes just past the .1 mark on the gauge. im pretty sure that the .1 equals 14.5 psi. Man i need a new boost gauge. but any way, its getting close to 15 psi and the notes call for 13.5. Should i adjust the WG or let it learn a little?
Wilks132 is offline
post #4 of 4 Old 11-17-2007, 12:23 AM
wrxman420's Avatar
The stock boost gauge is known to be a little unaccurate. You should be fine with the boost you are at now.
wrxman420 is offline
