First data log - Subaru WRX Forum
post #1 of 7 Old 07-09-2012, 10:33 PM Thread Starter
Tenormdnes is an unknown
First data log
Hello,
I have a 2012 WRX with a drop in K&N and Cobb stage 1 map (93oct). Here is my first data log. I just want to make sure everything looks OK. I've been reading a lot and am getting lost in some of the numbers.
Tenormdnes is offline
post #2 of 7 Old 07-10-2012, 11:45 AM Thread Starter
Anybody?
Sent from my DROIDX using AutoGuide.Com Free App
post #3 of 7 Old 07-10-2012, 12:00 PM
There are only a few on here that can actually give you details on how it looks (I'm not one of them).
Did you do this in when it was HOT outside? Did you run it up to RL? (not sure what RL is on your car).
I don't see your AF either on the log
post #4 of 7 Old 07-10-2012, 01:48 PM
How quick after flashing to the map did you run that log? You're not pulling timing or knocking, but your DAM is only at .81, where it should be a 1.00.
If you ran that log right after flashing that would explain it, but keep an eye on it and run logs to see if that DAM gets up to 1 as the car learns the map. Generally, I see the DAM jump up to 1 within a couple minutes of flashing a map.
post #5 of 7 Old 07-10-2012, 03:30 PM Thread Starter
2 new logs
Update. I was running a K&N drop in, and getting horrible gas mileage. I changed it back to stock and immediately saw an increase. (from 16.5mpg to 23ish).
Here are two new logs.
One is high waste gate 93oct stage 1, and the other is normal wastegate 93 oct stage 1.
Which one looks better?
I'm in Texas so its HOT, and I can't quite make it to red line around here without running out of room!
post #6 of 7 Old 07-11-2012, 06:22 AM
Pulled a bit of timing on the high wastegate map. The normal wastegate looks just fine.
post #7 of 7 Old 10-10-2012, 07:08 AM
tunertype is an unknown
what gear were you in? Also A/F ratio would be nice to see.
tunertype is offline
