Ecutek? - Subaru WRX Forum
post #1 of 7 Old 07-06-2007, 05:41 PM Thread Starter
nicolas316 is an unknown
Ecutek?
Just curious to know, i had installed ECUTEK map on my 07 WRX when it was still stock, with stock exhaust, my mechanic said that with stock exhasut ECUTEK gave me 255bhp with 390NM of torque is that possible? and now with 76mm catless pipes and a second ECUTEK map he says i have about 270bhp is that possible too?? and if anyone used ECUTEK, how much horse power did u gain?? what should be my next step in increaing horse power?
nicolas316 is offline
post #2 of 7 Old 07-06-2007, 06:40 PM
Ian
Ian's Avatar
Ian is more helpful than not
Send a message via AIM to Ian
I gained about 50 hp at the wheels with Ecutek. I also had a full turbo back exhaust, up pipe and intake. So depending on the dyno your numbers are not that far off, but I would say there a little high
Ian is offline
post #3 of 7 Old 07-06-2007, 08:25 PM
peedubbz's Avatar
peedubbz is an unknown
ok so whats better ECUTEK or cobb?
peedubbz is offline
post #4 of 7 Old 07-06-2007, 09:47 PM
koolpaul1082 is an unknown
either is really better that the other they are both piggy back em's. cobb is obvisiously better known and proven also easier to use. so its a little pricer i believe. whats more important is what supporting mods you use and lasting getting a protune will net you the most noticable power gains and reliablity.
koolpaul1082 is offline
post #5 of 7 Old 07-07-2007, 04:27 PM
peedubbz's Avatar
does cobb have to be plugged in while you use the map? everyone is talking bout hiding the wires . i was under the impression that you plug it in dl the map then through it in the glove box.
peedubbz is offline
post #6 of 7 Old 07-08-2007, 03:24 PM
no. You only plug it in when you want to reflash. The v2.0 though can be used to monitor boost, EGT, or other things though if plugged into the stock ECU while it's running. It's a reflasher though so once it flashes, it's not required.
The real advantage vs other flashes is that the cobb itself stores all your maps so you can change maps yourself or keep a copy of the professionally made map so that you don't have to run back to your tune shop if you loose it.
post #7 of 7 Old 07-08-2007, 06:14 PM
peedubbz's Avatar
yeah that sounds like a really nice upgrade. def. goin on the wish list.
peedubbz is offline
