dealership disaster - Subaru WRX Forum
post #1 of 3 Old 05-24-2010, 04:28 PM Thread Starter
Kyole's Avatar
dealership disaster
i recently took my 02 wrx into a local stealership for the fuel line recall. They completely the recall and not 5 miles down the road the cel comes on. I took it to my work and scanned the code with my pocket scanner and the code was p0031- front a/f sensor heater circuit low imput. i put a new sensor in it but nothing, still a hard fault even after cleared. i hastely returned to the stealership and told them all of this and they told me that there was absolutely no way that could of been caused by their repairs. Ive had the car for a little over a year and a half and never any problems but 5 miles after they "fix" it this happens. They told me there was probably a short somewhere in the harness. They refuse to fix it as well. My question is this: if i install a catless/sensorless uppipe and get a protune, could there be a set a/f ratio and would the ecm completely ignore this problem?
Kyole is offline
post #2 of 3 Old 05-24-2010, 05:40 PM
The sensor in the up pipe isn't O2, its just an egt. You can't remove the O2 sensor in the exhaust manifold if you want the car to work, it needs it.
post #3 of 3 Old 05-24-2010, 09:19 PM Thread Starter
Kyole's Avatar
if i unplug the connector for the front a/f sensor my car runs no differently. There is a short somewhere in the harness that the dealer refuses to fix and i dont have the time to go through the engine harness all the way through to the ecm.
Kyole is offline
