Coolant leak?! Had for months! - Subaru WRX Forum
post #1 of 10 Old 03-04-2014, 11:15 AM Thread Starter
justin93m is an unknown
new to this forum, but i have an 03 wrx engine and transmission have both been replaced, did not replace thermostat or water pump. i have a coolant leak but only when the car starts and is cold, but once it gets to normal temp there is no more leak. brand new headgaskets from cometic put on 3 months ago. water pump? bad Rad? the resivoir will drain but the car wont overheat till its empty, oil is fine and no smoke or anything? HELP PLEASE!!!
Any ideas please!
justin93m is offline
post #2 of 10 Old 03-04-2014, 11:22 AM
06_hawk_eye's Avatar
06_hawk_eye is an unknown
Pressure test?
Sent from AutoGuide.com App
06_hawk_eye is offline
post #3 of 10 Old 03-04-2014, 11:26 AM Thread Starter
tested it and it held pressure and no leak, but it might have been warm when they did it
post #4 of 10 Old 03-04-2014, 12:08 PM Thread Starter
any other suggestions, i took it to the dealership and they didnt even know what was wrong. just once the car starts it leaks then will get to normal temp and not leak, a gasket? but which one?
post #5 of 10 Old 03-04-2014, 01:07 PM
Epictofer's Avatar
Epictofer is known to be trustworthy and helpful Epictofer is known to be trustworthy and helpful Epictofer is known to be trustworthy and helpful
possible water pump seal- when the shaft is turning it could cause it to leak. that could be why its doing it only when its running. seen it happen on an audi once. other wise pressure test with it running, if that doesn't find it then drive it till it gets worse? no don't do that.
Epictofer is offline
post #6 of 10 Old 03-04-2014, 01:31 PM Thread Starter
yea, once i start the car it will leak, but when car reaches normal temp it wont leak again till the car gets cold and starts again.
post #7 of 10 Old 03-05-2014, 09:51 AM
you HAVE to be able to see where it's leaking from.
post #8 of 10 Old 03-05-2014, 10:05 AM Thread Starter
its coming from the area around th bottom rad hose.
post #9 of 10 Old 03-06-2014, 06:43 AM
replace the hose or at least take it off and chk for cracks. Might be something simple.
post #10 of 10 Old 03-06-2014, 08:28 AM Thread Starter
okay thank you!
