Coob Accessport V2 Question - Subaru WRX Forum
post #1 of 15 Old 11-08-2010, 06:35 PM Thread Starter
Harvey's Avatar
I have an 06 STi and i plan on buying a cobb accessport v2 this weekend. On the cobbtuning website it says i need a stock intake, but i have a k&n typhoon short ram. Will the accessport still work or will i need to put the stock intake back on??
Harvey is offline
post #2 of 15 Old 11-08-2010, 08:09 PM
If you're going stage 2, you should be getting custom tuned anyways.
post #3 of 15 Old 11-08-2010, 09:55 PM
Funny he didnt mention stage 2, nore do you absolutely HAVE to have a tune for stage 2.
As for the OP, that or any intake is just making noise for the most part, but you should be fine to run it.
post #4 of 15 Old 11-09-2010, 05:36 AM
I wouldn't stray from the map notes... personally. Get a drop in K&N until you are ready to go stage 2 with a tune.
Shame on you Josh.
post #5 of 15 Old 11-09-2010, 09:25 AM
The intake setups that work best with off-the-shelf Cobb maps are:
1. Cobb short ram intake (with or without heat shield box, preferably with)
2. SPT short ram intake (with or without heat shield box, preferably with)
3. stock intake with K&N (or other brand) drop-in replacement panel air filter (with or without snorkus delete mod)
If you still have the stock intake, it would probably be best to reinstall that and sell your typhoon for a few bucks if you plan on running a generic Cobb map for a while. If, however, you plan on getting more parts and/or a pro-tune via the AccessPORT in the near future, you can probably keep the intake you have.
post #6 of 15 Old 11-09-2010, 11:42 AM
The K&N doesnt cause problems. But like I said, and most of us know, its a noise maker. Maybe looks a little nicer than the stock setup. I know you shouldnt stray from the map notes, but Cobb does that for liability reasons.
post #7 of 15 Old 11-09-2010, 02:22 PM
True, I guess there's really only one way to find out for sure with his specific car: install the AP, select a map, drive for a while and see if there are any check engine lights or other ill effects... if so, just reinstall the stock intake and reset the ecu.
post #8 of 15 Old 11-09-2010, 04:05 PM
It's a very fair assumption. And no, it's not just a noise maker if he is actually going stage 2.
post #9 of 15 Old 11-09-2010, 09:54 PM
Why/how is it more than a noise maker at stage 2? Im just wondering, from all my research and asking/talking around, the 02-07 WRX/STI and the intake from the factory is rather capable of handling stage 2 power and then some more.
post #10 of 15 Old 11-10-2010, 12:00 AM
It's been proven time and again for years that intakes a decent power makers @ stage 2 for both WRXs and STIs. A few yers ago Harman Motive did an intake test and they were repeatedly gaining 10-15 whp on a stage 2 STI with an intake + tune over a custom tune on the stock intake. "Capable" is not the same as "ideal"; you have Cobb to thank for that often misquoted 350 hp mess. Just because the stock intake is capable of handling xxx amount of power, that doesn't mean that it's not a restriction before xxx power is reached.
post #11 of 15 Old 11-11-2010, 07:49 PM Thread Starter
Harvey's Avatar
i will be getting a tune for stage 2 btw
Harvey is offline
post #12 of 15 Old 11-12-2010, 05:25 AM
The Intake will make a difference on a stage2 tune. Before that, probably not.
post #13 of 15 Old 11-14-2010, 09:09 AM Thread Starter
Harvey's Avatar
ok, so im tryin to put the AP on but everytime after i select the vehicle it says communicating with ECU for bout 10 min then its says cxable not connected or mis-configured i cant get it to work!?!?!?
Harvey is offline
post #14 of 15 Old 11-14-2010, 08:51 PM
Did you have the car in test mode?
post #15 of 15 Old 11-15-2010, 05:44 PM Thread Starter
Harvey's Avatar
yes it was in test mode
Harvey is offline
