Cobb Stage 2 91 - Subaru WRX Forum: WRX Forums
» Auto Insurance
Go Back   Subaru WRX Forum: WRX Forums > WRX Tech Forums > Tuning & Engine Management
Old 10-19-2012, 04:30 PM   #1 (permalink)
Reputation: squishd is an unknown
Cobb Stage 2 91
Alright well here is my data log on my accessport stage 2 on 91 octane. I am not getting the boost I should have. I double checked and i have the pill, I dont want to adjust my wastegate arm anymore. I have a catless up, down, Cobb intake, aps 50/50. The only thing i can think is that i have a cracked intercooler hose or something? Not sure though, maybe someone with much more experience then me can take a look and see what they think...
Offline   Reply With Quote
Old 10-19-2012, 04:35 PM   #2 (permalink)
Maybe this one is easier to read?
Old 10-26-2012, 04:59 PM   #3 (permalink)
Alright well here is where i am at with this... I dont have any boost leaks up to over 20 pounds for sure. My boost will sit right at 8 pounds. I disconnected the line from the boost actuator to the t and sealed it off. It will boost to the moon... Does that mean I have a bad boost solenoid?
Old 10-27-2012, 10:01 AM   #4 (permalink)
pzr2874's Avatar
Car: 2007 MazdaSpeed3
Club Region: Gulf Coast
Reputation: pzr2874 is known to be trustworthy and helpful pzr2874 is known to be trustworthy and helpful
It's showing hitting 11lbs where it should be hitting 16 right?
Are you sure it's flashed correctly? You did a "reflash", not a realtime flash, correct? And this is a 3rd gear pull?
Do another log with the correct stock BPV on there. Report back with a log
2007 XT
Old 10-27-2012, 10:50 AM   #5 (permalink)
pzr2874's Avatar
Did you update your firmware before flashing? And do you have a stock intake around? Running catless isn't recommended either.
Tighten your WG arm a beaverhair and then go log again.
2007 XT
Old 10-27-2012, 01:05 PM   #6 (permalink)
I bought the car used so I do not have the stock bpv or air intake. I have a cobb intake on it though. Yes it is a reflash... and yes a third gear pull. I have an aps downpipe, it does have a high flow cat on it. And yes i just updated the filmware before I reflashed. For some reason im almost certain it is my Boost solenoid. Aren't you suppose to be able to hear it click when you have it in service mode? I dont hear it at all.
Old 11-01-2012, 12:38 PM   #7 (permalink)
Well... Installed my 3 port boost solenoid last night and got my car tuned today. 237hp on stage 2 with an Sti intercooler. I'm pretty pumped.
Old 11-05-2012, 07:45 PM   #8 (permalink)
Reputation: tunertype is an unknown
congrats on getting everything sorted. those are pretty good numbers.
Old 11-22-2012, 01:50 PM   #9 (permalink)
Williams144's Avatar
Reputation: Williams144 is an unknown
Access port
What do you guys think is the best cobb access port for a 08 wrx hatch?
Old 11-23-2012, 11:33 PM   #10 (permalink)
Alexmartynyuk's Avatar
Reputation: Alexmartynyuk is an unknown
the one that will work with that year.
