-   -   Cobb Stage 2 91 (http://www.wrxtuners.com/forums/f70/cobb-stage-2-91-a-33178/)
squishd 10-19-2012 04:30 PM
Cobb Stage 2 91
1 Attachment(s)
Alright well here is my data log on my accessport stage 2 on 91 octane. I am not getting the boost I should have. I double checked and i have the pill, I dont want to adjust my wastegate arm anymore. I have a catless up, down, Cobb intake, aps 50/50. The only thing i can think is that i have a cracked intercooler hose or something? Not sure though, maybe someone with much more experience then me can take a look and see what they think...
squishd 10-19-2012 04:35 PM
1 Attachment(s)
Maybe this one is easier to read?
squishd 10-26-2012 04:59 PM
Alright well here is where i am at with this... I dont have any boost leaks up to over 20 pounds for sure. My boost will sit right at 8 pounds. I disconnected the line from the boost actuator to the t and sealed it off. It will boost to the moon... Does that mean I have a bad boost solenoid?
pzr2874 10-27-2012 10:01 AM
It's showing hitting 11lbs where it should be hitting 16 right?
Are you sure it's flashed correctly? You did a "reflash", not a realtime flash, correct? And this is a 3rd gear pull?
Do another log with the correct stock BPV on there. Report back with a log
pzr2874 10-27-2012 10:50 AM
Did you update your firmware before flashing? And do you have a stock intake around? Running catless isn't recommended either.
Tighten your WG arm a [COLOR="Lime"]beaverhair[/COLOR] and then go log again.
squishd 10-27-2012 01:05 PM
I bought the car used so I do not have the stock bpv or air intake. I have a cobb intake on it though. Yes it is a reflash... and yes a third gear pull. I have an aps downpipe, it does have a high flow cat on it. And yes i just updated the filmware before I reflashed. For some reason im almost certain it is my Boost solenoid. Aren't you suppose to be able to hear it click when you have it in service mode? I dont hear it at all.
squishd 11-01-2012 12:38 PM
Well... Installed my 3 port boost solenoid last night and got my car tuned today. 237hp on stage 2 with an Sti intercooler. I'm pretty pumped.
tunertype 11-05-2012 07:45 PM
[quote=squishd;287418]Well... Installed my 3 port boost solenoid last night and got my car tuned today. 237hp on stage 2 with an Sti intercooler. I'm pretty pumped.[/quote]
congrats on getting everything sorted. those are pretty good numbers.
Williams144 11-22-2012 01:50 PM
Access port
What do you guys think is the best cobb access port for a 08 wrx hatch?
Alexmartynyuk 11-23-2012 11:33 PM
[quote=Williams144;287990]What do you guys think is the best cobb access port for a 08 wrx hatch?[/quote]
the one that will work with that year.
