Cobb AP stage 1 hwg not hitting full boost. - Page 2 - Subaru WRX Forum
 1Likes
post #16 of 40 Old 02-07-2014, 04:10 PM Thread Starter
Bubba James's Avatar
Bubba James is an unknown
Well, no cracks in the lines..that I can see anyway. Are there certain lines I should be looking for? Stressin' me out. The struggle, man.
Bubba James is offline
post #17 of 40 Old 02-07-2014, 04:21 PM
Hmmm, I'll make a stink about the guest thing.
post #18 of 40 Old 02-07-2014, 04:26 PM Thread Starter
Ok it keeps telling me invalid format. So heres a screen cap from todays pull. Ive notived that the fine knock has now showed up....is this cause for concern? Should I go back to the normal map and not high waste gate?
post #19 of 40 Old 02-07-2014, 04:32 PM Thread Starter
And here are the other two from today. Datalog5 was from this am going into work at about 30º. That was a true 3rd gear pull getting on the freeway with no traffic. 6 and 7 i had to cut throttle for the "out of work" crowd. Blue is boost, red is knock.
post #20 of 40 Old 02-07-2014, 04:47 PM
thekamikaze kid's Avatar
yah i would try sending your log to cobb, they review logs for free. i also noticed your DAM (IAM) is at 13, should be at 16. the first datalofg i did i had a DAM/IAM of 11 and it ended up being just a dirty maf sensor. after sending to cobb they told me that a low DAM/IAM meant there was a mechanical problem. so i believe your issue isnt tune related. but of course i am still learning this stuff so...
thekamikaze kid is offline
post #21 of 40 Old 02-08-2014, 08:44 AM
That knock COULD be from crappy gas. I've always added 1 gal of e85 to a tank to rule out the gas issue (to raise the octane).
Need to see a full WOT log in 3rd if possible.
post #22 of 40 Old 02-08-2014, 06:27 PM Thread Starter
Full WOT 3rd is datalog5 in the images I posted. And I would assume it isn't crappy gas. Its a relatively new gas station with new pumps and all that, backed by a grocery chain. I would hope it wasn't crappy gas anyway.... I'm leaning towards a mechanical issue as suggested by the peeps on this thread. Slight hesitation when going 2k-3k rpm WOT. And I do mean slight. Passenger couldn't feel it, but I sure as hell could. Intermittent too. It was worse on the HWG map.
post #23 of 40 Old 02-08-2014, 06:43 PM
I had the exact same problem, it started as hesitation, and after a while it started bucking. Try cleaning your maf sensor. Although I wasn't under boosting like you are.
post #24 of 40 Old 02-08-2014, 06:53 PM Thread Starter
Just cleaned that little dude! There's a T splitter in the line running to wastegate that has one end capped so the air travels at a right angle. May be an issue to look into. Sprayed boost line down with soapy water and couldn't find a leak anywhere. Going to leak test at a shop to be sure. Hesitation isn't as prominent on this base map. Very rare, actually.
post #25 of 40 Old 02-08-2014, 07:16 PM
Little dude, fol, well let us know how u fix it!
post #26 of 40 Old 02-08-2014, 08:53 PM Thread Starter
Will do, Brobama.
post #27 of 40 Old 02-08-2014, 11:53 PM
DAM You!!!
Technical Articles
post #28 of 40 Old 02-09-2014, 12:03 AM Thread Starter
So it's possibly cutting my boost due to knock being sensed?
post #29 of 40 Old 02-09-2014, 12:23 AM Thread Starter
Knock from bad gas, I meant. May be worth the trip to a E85 station.
post #30 of 40 Old 02-09-2014, 01:35 AM
