I have a stage 2 93 octane low wastegate map flashed to the EC?U of my 2002 WRX 4EAT. Well today U just filled up at the local Shell gas station with 93 octane like Ive done dozens of times before. I also just uploaded my datalogs to my parents computer and got a message about my backup ECU map not showing up in my Accessport and the popup message prompted me to backup my ECU or something like that so I clicked "OK". So I connected my Accessport to my OBDII port and drove home. On the way home I noticed that at low speeds(35 and under) my fine knock learning and another knock gauge were jumping around, but my fine knock learning kept jumping all the way up to -11.45!!! It would also bounce around 1.3, 2.xx and a couple other spots but as soon as I applied throttle or got u pto cruising speed it went back down to 0.00.
Should I be worried right now? Because I am. Big time. This has never happened before. MY car seems to be running just as well as it has been since I flashed to this low wastegate map last week. I installed the low wastegate map because I was overboosting. I am still overboosting. 19.76 pounds at 5100 RPM. The LWG map did nothing for me. Are these related? This all started happening after doing a datalog and pushing my 4EAT and EJ205 up to 5100 RPM in 3rd gear so I could get a decent datalog. Then I plug my Accessport into my parents PC, get that weird message and once I drive back home I started having these problems with my fine knock learning. I really need some help here, because I know those parameters are WA?Y out of spec. Thank you in advance for your help.
