-   -   Cobb AP 2.0 CEL? (http://www.wrxtuners.com/forums/f70/cobb-ap-2-0-cel-23668/)
ovk2k5 07-05-2008 05:11 PM
Cobb AP 2.0 CEL?
I am hopefully getting an 04 wrx on monday and that being said, I will be buying a Cobb AP 2.0. With that, can I turn off a CEL? I am going to swap out the up and down pipes with catless ones just bc I am paranoid and am going to be doing more mods eventually. But in the meantime to pass inspection I need no CEL so does the AP have the ability to turn off the light or do I need something else? If I need something else, what would you recommend?
Vew 07-05-2008 10:30 PM
Yes, it can disable CELs.
ovk2k5 07-05-2008 10:37 PM
sweet thanks, now I can actually mod my car in NY. If I can get it that is.
man show 07-05-2008 10:42 PM
Yep, the Cobb AP can read the CEL code(s), tell you specifically what the code(s) is/are, and turn the light off for you. No need to be paranoid. As a backup plan, you can also take your car to your local Auto Zone (or similar auto parts store) and tell them that your check engine light is on and they will be able to run a quick diagnostic test (usually for free) and tell you what code(s) is/are causing the CEL. To clear the light yourself, just unplug your car battery and step on the brake pedal for a few seconds until all the power is gone. This will reset your ECU and the CEL will be cleared.
Good luck with your possible purchase!
ovk2k5 07-05-2008 10:48 PM
Really? Thats cool I didn't know you could clear it like that. Yeah it's $16,488 and I have like $1500 in negative on my trade so if they can get it for $350 a month or less then I'll take it. Can't really afford much more than that. As long as they can do a 72 month loan I should have no problem. And this car is def worth 6 years of payments compared to the 4 year left on my 3g 4cyl eclipse with NO after market at all.
ovk2k5 07-05-2008 11:29 PM
so $695 for the AP will probably take me a little while to save up, but I found it on a website for $695 plus $14 for ground shipping. I was just shopping around on ebay and found the same thing brand new for $695 with free overnight shipping. Kind of odd that there are a ton on ebay for that price and how many people won't even look bc it's ebay.
newtothegame 07-06-2008 12:32 AM
Rallysportdirect.com is $695, anything ordered from them over $200 is free shipping. I had my Cobb AP in 2 days from them when I order it right after its realese.
man show 07-06-2008 08:24 AM
WeSellCarParts.com has the Cobb AP for $695 w/ free shipping in the continental US. If you want to save a little more dough, you could always search for a used AP on eBay or elsewhere. As long as you make sure it's compatible with your exact car, it should be just as good as a brand new unit. I'd be willing to bet that 9 times out of 10 it's only used a handful of times and then spends the rest of its life packed neatly in the box it came in. Every AP is good for hundreds of uses, btw. Just a thought.
yelljack 07-20-2008 09:45 PM
[QUOTE=man show;200121]WeSellCarParts.com has the Cobb AP for $695 w/ free shipping in the continental US. If you want to save a little more dough, you could always search for a used AP on eBay or elsewhere. As long as you make sure it's compatible with your exact car, it should be just as good as a brand new unit. I'd be willing to bet that 9 times out of 10 it's only used a handful of times and then spends the rest of its life packed neatly in the box it came in. Every AP is good for hundreds of uses, btw. Just a thought.[/QUOTE]
I've had mine for a month, it has been out of the box once, and I have no reason to plug it back in. Take his advice buy used!
