Cobb Accessport. Not reaching full boost. WDC? - Page 2 - Subaru WRX Forum
post #16 of 20 Old 07-28-2012, 10:54 AM Thread Starter
SubiSwag's Avatar
SubiSwag is an unknown
Send a message via Skype™ to SubiSwag
I adjusted my wastage 1.5 turns. I got up to 14.7psi in third gear at 4010rpm. 15.7psi in 4th gear at 4120 rpm and i got 16.2psi in 5th gear at 3560rpm. Is this where i should be in stage 2?
SubiSwag is offline
post #17 of 20 Old 07-28-2012, 11:13 AM
Should be pretty consistent through out all gear, bit lower in first usually
post #18 of 20 Old 08-23-2012, 10:23 PM
wick'd's Avatar
wick'd is an unknown
im having this same problem but only getting around 8psi:s
wick'd is offline
post #19 of 20 Old 08-24-2012, 10:07 AM
^YOU prob have a boost leaks(s). Look under your TMIC... Inlet and y-pipe
post #20 of 20 Old 08-26-2012, 01:18 AM
wick'd's Avatar
no tmic leaks, sealed it all up just to be safe. took it out later in the afternoon checked it, no gain. searched threads and came up with some possible reasons. leak under tmic (already mentioned), junk bcs, checked vac line routing and restrictor pill. come to find out my girl isn't on the pill :O haha logical reason for it to underboost. leads me to believe my scoob was tuned before i bought it, the joy of buying used cars!
wick'd is offline
