-   -   Cobb Accessport. Not reaching full boost. WDC? (http://www.wrxtuners.com/forums/f70/cobb-accessport-not-reaching-full-boost-wdc-32795/)
SubiSwag 07-24-2012 10:36 PM
I have an 03 WRX with APS turboback exhaust, sf intake. Im was running Stage 2 93. I couldn't reach full boost so i flashed the Stage 2 93 hwg and still can't reach full boost. I data logged 13.52 Psi in 3rd gear at 3850 RPMS this is all i can boost. At the same time my wastage duty % is only at 91.76. (IDK IF this should be higher or lower).
Please help me reach full boost. Idk what to do I'm kinda noob. I read that you have to wait approx. 250 miles for ECU to fully use new map (is this true or false)?
What i'm asking if for any help or advice to reach peak boost. Thanks
Alexmartynyuk 07-24-2012 11:48 PM
[quote=SubiSwag;282970]I have an 03 WRX with APS turboback exhaust, sf intake. Im was running Stage 2 93. I couldn't reach full boost so i flashed the Stage 2 93 hwg and still can't reach full boost. I data logged 13.52 Psi in 3rd gear at 3850 RPMS this is all i can boost. At the same time my wastage duty % is only at 91.76. (IDK IF this should be higher or lower).
What i'm asking if for any help or advice to reach peak boost. Thanks[/quote]
I'm guessing your using the stock bcs right? what ambient air temp? stock uppipe? any cels?
psinuse 07-25-2012 05:14 AM
Does your car still have the pill in it?
SubiSwag 07-25-2012 07:36 AM
[quote=Alexmartynyuk;282971]I'm guessing your using the stock bcs right? what ambient air temp? stock uppipe? any cels?[/quote]
Stock BCS. I didnt log the air temp. Stock uppipe and no CEL
[quote=psinuse;282978]Does your car still have the pill in it?[/quote]
Yes it still has the pill. Should it be removed or modified?
pzr2874 07-25-2012 08:22 AM
No, look into loosening and tightening your WG arm on COBB's website if you aren't getting target boost.
psinuse 07-25-2012 11:07 AM
[quote=pzr2874;282987]No, look into loosening and tightening your WG arm on COBB's website if you aren't getting target boost.[/quote]
...and that's where i was going.
pzr2874 07-25-2012 11:39 AM
I know.... that's why I posted it for you.... hahaha
psinuse 07-25-2012 12:15 PM
[quote=pzr2874;282998]I know.... that's why I posted it for you.... hahaha[/quote]
Great now you sound like my wife....:p
RcrsWetDream 07-25-2012 12:17 PM
1 Attachment(s)
Could just be a boost leak as well. I would start there before going and adjusting crap.
pzr2874 07-25-2012 02:13 PM
^True.
Then again, I missed the part where he was a newbie to FI
Good call Chris
psinuse 07-25-2012 04:31 PM
Does the boost fluxuate or does it stay at 13psi for the most part?
*side note*Why is fluxuate underlined in red...It's a word isn't it????
SubiSwag 07-25-2012 07:27 PM
the boost does not fluxuate it stays constant at just under 14 psi. it wont go over though.
psinuse 07-25-2012 07:46 PM
I know this goes against the grain, but try resetting the ECU and report back. If it doesn't change it then try taking out the pill and see what happens.
SubiSwag 07-25-2012 08:07 PM
Okay thanks man. i will try both of those things and see what happens.
Should i adjust the wastage arm? I read the post about it. I will try theses 3 things and will report back with my findings...Thanks guys!!:D
([url]http://www.wrxtuners.com/forums/f70/how-adjust-your-wastegate-arm-18241/[/url])
