Check Engine Light?? - Page 2 - Subaru WRX Forum
post #16 of 37 Old 12-04-2007, 09:20 PM Thread Starter
SUBY777 is on thin ice
Cool why intake
if u havent heard exhaust and intake make a bigger diff on turbo cars over nonturbo. i saw an increase in acceleration
SUBY777 is offline
post #17 of 37 Old 12-04-2007, 09:21 PM Thread Starter
and..........
a little bit more power....i felt a diff in just a short ram..
SUBY777 is offline
post #18 of 37 Old 12-04-2007, 10:16 PM
Not to rain on your parade or anything, but most of that is in your head. Do you have numbers to prove any of it? There has been threads/posts about this, some guys are running close to 350 AWHP on the stock airbox still, with pics and dyno that show this. Just a thought though.
post #19 of 37 Old 12-05-2007, 07:42 PM
Blakkboxer's Avatar
Blakkboxer is an unknown
shit. 'check engine' light is back What to do??
Blakkboxer is offline
post #20 of 37 Old 12-05-2007, 09:09 PM
a.young's Avatar
a.young is an unknown
Originally Posted by D Cutz View Post
shuld get yoself an cob acessport if yo gonna be clearn codes and shit bro an then you can atleas find out what them codes be.
this is a joke right
stage 2 STi...and still not enough
a.young is offline
post #21 of 37 Old 12-06-2007, 12:35 AM
awd4life's Avatar
awd4life is an unknown
You need to pull the code and see what is up... That will dictate your next move.
awd4life is offline
post #22 of 37 Old 12-06-2007, 01:11 AM
It would seem that way. But I guess if you are gangster that is how it goes. I think we need to find us an interpretor so we can understand that crap.
post #23 of 37 Old 12-06-2007, 01:40 AM
As goofy as he typed it he is absolutley correct. Don't just clear codes left and right, if something is messed up and you keep clearing the code you could end up with some serious issues.
777 go to the newbie forum and read the stick about CAIs and intakes...
I can almost garentee your car didn't get any faster and it may have even lost a little bit.
Robby
02 rex is gone.
I defected to an evo :)
Evo is gone :(
Now I got nothing.
WRXKidid775 is offline
post #24 of 37 Old 12-06-2007, 02:27 AM
Imprt4life's Avatar
Imprt4life is an unknown
Send a message via AIM to Imprt4life
A good short ram wont give you problems. A cold air with no tune will give you problems. The only plus you'll get out of a short ram is that you'll probably hear your turbo spool from inside the car.
By disconnecting the battery to get rid of a CEL, you could be ignoring a serious problem. The CEL is there for a reason, not to be ignored. Get the code read and take care of the issue before it becomes an even bigger problem.
Imprt4life is offline
post #25 of 37 Old 12-06-2007, 12:19 PM
awd4life's Avatar
Just to clarify, I suggested the battery code clear because he said that the filter was improperly secured and popped off leading to a CEL. The ECU will often slip into a "safe mode" triggered by bad (low octane) fuel and not return to a regular mode untill the ECU is reset. It was this line of thought that led me to try the reset just in case the CEL was a "something is wrong with the engine and I am in a safer mode" message from the ECU.
Now that the light is back, agree that there is something that needs to be checked out. Pull the code and then go from there.
awd4life is offline
post #26 of 37 Old 12-11-2007, 06:27 PM
Blakkboxer's Avatar
got the code.. its "system is too lean" ..fu## gayy. i talked to a couple of my Scooby friends.. and said i gotta get a tune ASAP cause i'm at Stage 2 now (headers w/ uppipe,3" downpipe,3" piping from turbo to exhaust, a shitty bov that flutters i think its doing compresser surge ,Pulleys, and Manual boost controller under the hood which i need to get rid of quick. i hear its dangerous to have on..
post #27 of 37 Old 12-11-2007, 06:28 PM
Blakkboxer's Avatar
oh yes i have a AEM short ram intake.
post #28 of 37 Old 12-11-2007, 08:59 PM
I would try and get either the stock BPV or some other type, and get rid of the boost controller also like stated. That could possibly fix everything there, but the tune would definetly help also.
post #29 of 37 Old 12-11-2007, 10:10 PM
Blakkboxer's Avatar
thank god i still have the stock bpv as in bov? right? How do i take out the manual boost controller and plug up those 2 vaccuum hoses? how loud is the stock bov?
post #30 of 37 Old 12-11-2007, 11:22 PM
Blakkboxer's Avatar
Actually guys.. i turned down my manual boost controller screwed all the way in.*sunday* but when i got home sunday i reset my ECU by unplugging battery for 10 minutes it went away for only a few hours**so i'm running at stock psi. CEL was on all day sunday and monday..and just today i took a quick drive to the store then my CEL is gone..hrmm yay!
