Check Engine Light?? - Subaru WRX Forum
post #1 of 37 Old 12-02-2007, 07:22 PM Thread Starter
SUBY777 is on thin ice
Question Check Engine Light??
I Installed A New Short Ram And It Was Going Great Until I Raced A Crossfire V6 (i Destroyed Him By Like 6-7 Carlengths) After The Check Engine Light Turned On. I Stopped The Car And Popped The Hood. The Filter Was Not Secured And Came Off. I Tighted The Filter And Now Its Running Great. But.....i Still Have The Check Engine Light On. How Can I Take That Light Off.??????????
SUBY777 is offline
post #2 of 37 Old 12-02-2007, 07:34 PM
disconnect battery, pump brakes and reconnect it. if it doesn't go away go to auto zone and they will diagnose the CEL.
post #3 of 37 Old 12-02-2007, 09:06 PM
SWFL Scooby's Avatar
SWFL Scooby is an unknown
Pull code for CEL- if that's your only mod, it may be coming from the MAF
D-Rock
Under constant pressure
SWFL Scooby is offline
post #4 of 37 Old 12-03-2007, 01:51 AM
awd4life's Avatar
awd4life is an unknown
I vote you do both of these things. Pull the code, and if it your MAF, make sure everything is secure and reset the ECU.
awd4life is offline
post #5 of 37 Old 12-03-2007, 08:47 PM Thread Starter
Talking Good Call
Good Call On Unplugging The Battery. No More Check Engine Light!!!! Thanks Guys.
SUBY777 is offline
post #6 of 37 Old 12-03-2007, 09:01 PM
awd4life's Avatar
Glad it worked bro. The ECU will sometimes get set on a setting if there is too much/not enough of something, and it just needs a good reset.
This is also true for fuel maps. Our cars require at least 91 octane, but it says that sub premium can be substituted for a short time. This will put the ECU into a safe mode that will not actually switch back to the premium map on its own. It requires this reset. Sooooo, moral of the story is if you take a road trip it might be a good idea to reset the ECU when you get back to the gas your car is accustomed to.
awd4life is offline
post #7 of 37 Old 12-03-2007, 09:02 PM
awd4life's Avatar
Oh, by the way Suby777, you should let us have some of the gold you guys have over there for helping you out!!!
awd4life is offline
post #8 of 37 Old 12-03-2007, 09:20 PM Thread Starter
Cool Lol
I Cant Even Get To The Gold. All I Can Offer Is A Race If You Ever Pass By Here.lol.
SUBY777 is offline
post #9 of 37 Old 12-03-2007, 09:24 PM
Blakkboxer's Avatar
Blakkboxer is an unknown
how long should i wait?
Blakkboxer is offline
post #10 of 37 Old 12-03-2007, 09:29 PM
awd4life's Avatar
There is a little search tab that would help you answer that question.
ECU reset question
awd4life is offline
post #11 of 37 Old 12-03-2007, 09:46 PM
Blakkboxer's Avatar
ECU reset question
Nevermind. i disconnected the battery and pumped the brakes for 30 seconds.. "Check Engine" light is gone woot!
post #12 of 37 Old 12-04-2007, 09:22 AM
good, stuff!!!! i learned that from other members here on this website.
post #13 of 37 Old 12-04-2007, 03:23 PM
D Cutz is an unknown
shuld get yoself an cob acessport if yo gonna be clearn codes and shit bro an then you can atleas find out what them codes be.
D Cutz is offline
post #14 of 37 Old 12-04-2007, 05:41 PM
eighth08's Avatar
eighth08 is more helpful than not
Send a message via AIM to eighth08
question for you.. why did you get an intake?
Gregory-
keep it in the dirt.
eighth08 is offline
post #15 of 37 Old 12-04-2007, 06:43 PM
az_wrx_26's Avatar
az_wrx_26 is an unknown
So how much power does every one make?
az_wrx_26 is offline
