Check ECU MAP - Subaru WRX Forum
post #1 of 12 Old 08-08-2011, 11:24 PM Thread Starter
GamerzBM's Avatar
GamerzBM is an unknown
Check ECU MAP
how to chedck what ECU map i have i want to go to stock if its not already there is there any way to check it?
GamerzBM is offline
post #2 of 12 Old 08-08-2011, 11:45 PM
You can get someone to read the map that's on there and then check it against a known stock map. Do you know anyone that does open source tuning?
Kjott21 is offline
post #3 of 12 Old 08-08-2011, 11:53 PM Thread Starter
GamerzBM's Avatar
no i dont if i were to do it myself what would i have to do i already have the laptop and the software
GamerzBM is offline
post #4 of 12 Old 08-09-2011, 04:56 AM
Do you have the correct tactrix cable and flash block, without those you can't really do it.
post #5 of 12 Old 08-09-2011, 12:28 PM
Maybe you should check this shop out. It's about an hour from you from the looks of it.
Company Name: Dent Sport Garage
Tuner Names: Matt
Phone: refer to site
Website: DSG - DENT Sport Garage
Dyno Type: Dyno Dynamics
OpenECU Custom Tuning Session (Open ECU Reflash & Dyno graph)
$500
Kjott21 is offline
post #6 of 12 Old 08-09-2011, 12:36 PM
As mentioned you would need a cable and flash block. Then you would read the map with EcuFlash and then you could open it with RomRaider and compare it with a stock map. The injector settings will tell you if the map is set up for Pinks or stock injectors.
RomRaider - Open Source ECU Tools | Documentation / Getting Started
Kjott21 is offline
post #7 of 12 Old 08-09-2011, 03:40 PM Thread Starter
GamerzBM's Avatar
TY I CONTACTED DSG and they are going to look at it for 50 dollars and fix it if its not stock :-)
GamerzBM is offline
post #8 of 12 Old 08-10-2011, 10:52 PM
Glad you got it taken care of.
Kjott21 is offline
post #9 of 12 Old 08-17-2011, 11:51 PM Thread Starter
GamerzBM's Avatar
yes good news it was tuned for STI injectors and i got it back to stock injectors bad new i have a STI turbo i need pink injectors and another tune for it lol
GamerzBM is offline
post #10 of 12 Old 08-18-2011, 06:38 AM
Mine are up for sale on Ebay.
Subaru STi "pink" injectors | eBay
Place a bid and see if you win them...I could stop the auction if you really wanted them.
post #11 of 12 Old 08-18-2011, 09:14 PM Thread Starter
GamerzBM's Avatar
how much are you looking for them i really only need 3 because i have 1 alraedy :-) but if its low i will buy all i guess
GamerzBM is offline
post #12 of 12 Old 08-31-2011, 10:19 AM
joshtimber is an unknown
Do you still have those? I am looking for them too.
[removed]
joshtimber is offline
