-   -   Bcs (http://www.wrxtuners.com/forums/f70/bcs-44505/)
RickyTurbo11 02-01-2014 04:58 PM
Bcs
Shifting on the highway from 4th to 5th and got a PO224. It has only happened once before but it was the same situation, highway shifting from 4th to 5th. Would say a grimmspeed electronic boost control solenoid fix this? I bought one and took it to get installed at my tune, but my tuner said don't bother ### my solenoid duty was low. I didn't get a fuel cut because my car kept going fine so I'm thinking it was overboost. Could this be the wastegate? boost control solenoid? Or too much bad pressure running catless?
BLAZE2099 02-01-2014 05:02 PM
^ delete all of the above and state your case without any words of street racing.
It is prohibited
Edit: thank you, OP responded immediately to my request per the forum rules.
RickyTurbo11 02-01-2014 05:19 PM
Thanks
Nathan21 02-01-2014 05:36 PM
Had the same issue, even though I replaced a bunch of other parts right at once, My tuner was telling me it had to deal with my EBCS so I went with grimmspeed and they had no issues at all
the RIOT act 02-01-2014 07:59 PM
Bcs
Boost spikes are gonna happen in later gears if WOT and shifting. The fact you're catless def isn't helping things. You're kinda "chasing the dragon" on this one. Some have success with only tuning to fix this issue. I've read plenty of posts about people trying ebcs with no avail, although I've seen the opposite more often. Being catless def isn't helping though...esp if on OTS maps! You're not protuned right?
RickyTurbo11 02-02-2014 03:32 PM
I am pro tuned. By a really good tuner. I do run a little rich in the low rpm range with his tune and I backfire if I dump a lot of fuel but besides that it's a very good tune I think. Unfortunately I tend to agree with you, since I'm cattless when I'm flooring it in a high gear and then shifting I can't expect not to boost spike I guess. I might try the ECCS but I might as well wait to save and do other things at the same time. No sense in paying all the money for another tune to just install a $100 part.
RickyTurbo11 02-02-2014 03:39 PM
What about a manual boost controller? Would that require a retune? Could that solve the problem? I really don't want to drive around and have to worry about boost spikes then pull off and clear the code.
boo-key 02-02-2014 04:40 PM
549 Attachment(s)
I had the same problem with my catless dp.
the RIOT act 02-02-2014 09:02 PM
Bcs
I'm protuned as well by BrenTuning who I'm sure you know of. I too spike a bit when WOT and shifting in 4th and 5th to 19.5 when I'm tuned to 18.5 otherwise. A Grimm ebcs is in the works. Although like you mentioned, doing other mods is what I'm waiting on. Don't waste your time with a manual unit! If you're spiking during normal use then I'd have a talk with your tuner, but if it's only higher gears at WOT I'd say just get enough supporting mods as soon as possible and get the ebcs lol! I've read MANY articles on this when I first initially had this same "problem" and there's really nothing you can do but try a ebcs. The car is lacking what's not there, and a tuner can only do so much. I'm catted too...and still spike btw.
And btw how the hell haven't we met up yet? Never even noticed you live in MA...
[edit] Don't dump the gas/clutch pedal and you'll be fine just FYI. Even just staging for a second solves the spike issue.
BLAZE2099 02-02-2014 09:40 PM
Manuals are bad news for our cars.
They won't learn it, but still be trying to accommodate the stocker.
RickyTurbo11 02-03-2014 06:57 AM
[quote=the RIOT act;430857]I'm protuned as well by BrenTuning who I'm sure you know of. I too spike a bit when WOT and shifting in 4th and 5th to 19.5 when I'm tuned to 18.5 otherwise. A Grimm ebcs is in the works. Although like you mentioned, doing other mods is what I'm waiting on. Don't waste your time with a manual unit! If you're spiking during normal use then I'd have a talk with your tuner, but if it's only higher gears at WOT I'd say just get enough supporting mods as soon as possible and get the ebcs lol! I've read MANY articles on this when I first initially had this same "problem" and there's really nothing you can do but try a ebcs. The car is lacking what's not there, and a tuner can only do so much. I'm catted too...and still spike btw.
[color=gray]Sent from [url=http://www.autoguide.com/mobile]AutoGuide.com App[/url][/color][/quote]
I too got my car tuned with Bren. He was excellent. Definitely gonna wait and try and do a top mount, fuel pump, injectors and the ECBS at the same time so I only have to do one tune. And yea I'm always around. I live in falmouth but work at a Subaru dealership in Raynham so I'm not far.
the RIOT act 02-03-2014 10:07 AM
Bcs
That would prob explain why we both spike lol!!
Not the biggest fan of his work. I'd recommend Wicked Innovations for future needs. I've found way too many shady things done by him with tuning to be able to trust him. And when I asked him about my spike problem all I got was a piss poor attitude and how it "wasn't his problem" and I shouldn't done this that and other things. Well, kinda would've been great to have all the info before hand...cause I would've done them! But I love how he recommended an ebcs AFTER my tune. And then I hit him up about my Forge BPV before this instance and he said "just take it off if you're having problems with it...you don't need it" well why the hell did you tell me I DID when I initially came to you? Had no answer...didn't even reply to me!
He's great until you question his work. I def won't be going back. Just my opinion though.
Oh, next time you talk to him ask him how 1/2 his tunes all have identical ending HP/TQ readings. Using base maps much?.?.I think so lol!!
Just be careful man...very shady dude!
NeverSummer 02-03-2014 11:48 AM
3port bcs won't cute boost creep/spike
Check this out!
[url]https://cobbtuning.zendesk.com/hc/en-us/articles/200140819-GR-Boost-Creep-Issues[/url]
Nathan21 02-03-2014 11:56 AM
wow good read Dave!!
NeverSummer 02-03-2014 11:59 AM
[quote=Nathan21;430929]wow good read Dave!![/quote]
Just trying to help people out who think the 3port is the fix etc
