Go Back   Subaru WRX Forum: WRX Forums > WRX Tech Forums > Tuning & Engine Management
Old 05-09-2009, 12:18 AM   #1 (permalink)
jed344's Avatar
Car: 04 WRX
Reputation: jed344 is an unknown
AP V2 stage 2 map ( boost issue)
i have a 04 wrx with turbo xs TBE, catless upipe, useing stage 2 91 octane map. i have acccesstuner race softwear and i did a data log today. 3rd gear 2-7k rpm and max boost i hit was 14.5. tried using HWG stage 2 map same max boost 14.5. any ideas why i cant get any higher boost? i have searched it was mid 70s today but i have never seen my guage go past 1bar it sits right about there.
Old 05-09-2009, 12:31 AM   #2 (permalink)
pb-king07's Avatar
Car: 04 WRX
Reputation: pb-king07 is an unknown
Is the map your using only set to 1bar?? you should not really be going any higher then 1bar on stage 2 anyways. Are you running the stock turbo?
Old 05-09-2009, 08:22 AM   #3 (permalink)
jed344's Avatar
Car: 04 WRX
yes im using the stock turbo but says target boost on map is 16.5 -/+.7psi
Old 05-09-2009, 11:04 AM   #4 (permalink)
Verify you have no preturbo exhaust leaks and boost leaks from the turbo compressor outlet to the throttlebody.The maybe try shortening the wastegate arm 1 turn at a time.This means shorten 1 full turn,log/check boost levels and if not hitting target boost do another full turn.If you do this before checking for exhaust leaks/boost leaks you will be chasing your tail..........
Aarg matey!
ECU Pirated by RomRaider
Old 05-10-2009, 11:55 AM   #5 (permalink)
jed344's Avatar
Car: 04 WRX
i think i know right were it is it if i have a leak lol ill try that and if it doesnt work ill try shortening the wastegate today
Old 05-10-2009, 08:31 PM   #6 (permalink)
jed344's Avatar
Car: 04 WRX
yea i think its a boost leak reasons are one at idle i run max 8 vacuum, used to overboost till i put on stock bov now i cant even hit target boost, noticed my spool time seemed to slow down. would those be reasons of boost leak?
Old 05-10-2009, 08:41 PM   #7 (permalink)
Timeslip: 9.999 @ 101.26
it's probably the gasket at the bov?
Old 05-10-2009, 08:56 PM   #8 (permalink)
jed344's Avatar
Car: 04 WRX
thinking so it was kinda crappy and i didnt have anything to seal it up with so its just the gasket there to stop leaks. so im going to get a new gasket and seal it up
Old 05-11-2009, 09:40 PM   #9 (permalink)
jed344's Avatar
Car: 04 WRX
ok i fixed the boost leak but still im only running 9 vacuum is that normal?
Old 05-12-2009, 02:18 AM   #10 (permalink)
Reputation: Kjott21 is known to be trustworthy and helpful Kjott21 is known to be trustworthy and helpful Kjott21 is known to be trustworthy and helpful
Yes -9 is about right.
Old 05-12-2009, 08:38 PM   #11 (permalink)
jed344's Avatar
Car: 04 WRX
ok sweet thanks for the help
