AP Stage 2 not much of a noticable difference. - Subaru WRX Forum
 1Likes
post #1 of 17 Old 06-05-2013, 05:52 PM Thread Starter
DaveC03wrx's Avatar
So i just put my down pipe on and flashed my car to stage 2 with the accessport. I was expecting a noticable difference. But my car almost feels more sluggish. Only real noticable difference is spool sound and it starts sooner. Any ideas?
DaveC03wrx is offline
post #2 of 17 Old 06-05-2013, 10:10 PM
What kind of downpipe? Was it a bellmouth or standard flange like the factory?
post #3 of 17 Old 06-06-2013, 05:37 AM
Premium Member
the RIOT act's Avatar
Catted?
Sent from AutoGuide.com App
Brandon - 13' SWP WRX Sedan
the RIOT act is offline
post #4 of 17 Old 06-06-2013, 03:41 PM Thread Starter
DaveC03wrx's Avatar
Bellmouth decatted helix down pipe with hks hi power cb
post #5 of 17 Old 06-06-2013, 04:01 PM
Premium Member
AP + Catless DP = Problem. Unless you're protuned?.?.
Hit the search box OP
post #6 of 17 Old 06-07-2013, 12:34 PM Thread Starter
DaveC03wrx's Avatar
Its an 03 tho. Which from plenty of sources ive been told i can get away with quite a bit. I think the problem is my front o2 sensor in the manifold. I have a p0031 code so i have to fix that sensor. I saw on another thread that that can cause me to not reach boost target which im nowhere close to
post #7 of 17 Old 06-07-2013, 12:38 PM
Vendor
PROImportTuners's Avatar
^definitely fix the code.
An O2S code can definitely cause a loss of power, not to mention crummy gas mileage and other weird issues.
Once that's all sorted out I'm sure you'll be happy!
PRO Import Tuners
PROImportTuners is offline
post #8 of 17 Old 06-07-2013, 01:13 PM Thread Starter
DaveC03wrx's Avatar
Thanks man. Im gona fix it asap. Imagine going from stock to full stage 2 and feeling no difference.... i was sooo bummed
post #9 of 17 Old 06-07-2013, 02:31 PM
Again as I have said before, you can run a catted down pipe with an AP without issues. Replace the O2 and then reset your ECU. Should be good to go after that, unless there are other underlying issues.
post #10 of 17 Old 06-07-2013, 02:35 PM
Premium Member
Yes but being catless (no o2) plus an OTS map (doesn't accommodate catless) is where the problem lies. Those are things even you any get away with lol!
post #11 of 17 Old 06-09-2013, 02:59 PM Thread Starter
DaveC03wrx's Avatar
Ya idk ive heard too much on both sides of the issue. Ive heard plenty of people say that catless wont be ok but then pro tune shops have told me that the 02 and 03s are alright with it. Its going to be pro tuned at somepoint anyways. My question was more focussed to why i hadnt gained power. From my understanding either my bad front o2 sensor is causing it and/or i have a boost leak. Im going to change the o2 and put in a different up pipe and hope that takes care of it
post #12 of 17 Old 06-09-2013, 07:41 PM
Replace the O2 sensor and if you want to go catless you'll be fine.
post #13 of 17 Old 06-09-2013, 08:15 PM
Brockton's Avatar
My 08 is catless with a 02 fix, runs fine on the TP stage 2. As they said, get that code fixed and you should be fine. You'll love the power bump from the new map.
I know the feeling, when I went stage 2 I found out I had a boost leak in the actuator vac hose. Got that fixed only to have the coupler on my tmic leak because of the retarded rubber boots they put on the hose from the factory, took it off, no more leak. A couple weeks later thought I blew my turbo, high pitch squeeling under boost. After replacing the turbo it did the same thing. Did a boost leak test and found out it was the other side of the tmic to throttle body coupler. The rubber boot on the throttle body end blew out causing the high pitch squeal when the air passed through it. Took that boot off and clamped down the hose, finally running issue free.
Turbo cars can be a PITA, but they're worth it.
Brockton is offline
post #14 of 17 Old 06-09-2013, 08:22 PM
bullet85's Avatar
I just bought the AP tuner....im super excited to see how the stage 1 feels vs the stock tune
bullet85 is offline
post #15 of 17 Old 08-08-2013, 01:39 PM
Just went stage 2 on 93 octane yesterday and I have CATs removed. Haven't noticed any issues but I definitely noticed a hell of a lot more power. Dynamometer from 2nd gear read 290 hp and 270 tq to the wheels. Ready to do some highway pulls against my buddies stock STI
the RIOT act likes this.
Nhlnick is offline
