I'm looking for a VF34 to buy
A few pointers:Well if i had a few extra thousand laying around id proly get somthing larger (20g) with some of that thousand paying for a good tune. But since the 16g is so comparable to the vf34 and 39 and cobb has ots maps for them, im looking for a used sti turbo for now and then ill upgrade down the road.
From what ive searched it seems the oem turbos are so much more reliable than FP. I would go with the fp16g but since im buying used and taking into consideration the vf34,39 are too similar to the 16g and evidently have proven to be the most reliable, it almost seems like a no brainer.
My info is coming from 11 years of common knowledge on Subarus. The IHI VF turbos are cheap, that's why people get them; not because they were ever the best performing because they aren't. Until the EVO3 16G was replaced by larger variants of the 16G, it was regarded as the best turbo for 2.0L WRXs. It spooled faster than and made slightly more power than the OEM STI turbos. IMHO you are on a wild goose chase since there is no distinguishable performance difference between the VF34 and a 39/43. Why would you look for a turbo that's getting harder and harder to find because nobody has bought them new for many years (meaning they are all higher mileage) when you can catch a USDM STI turbo for $250-350 just by spitting in the wind?Im referring to the small 16g which is as far as I can tell virtually the same as a vf. A big 16g Id assume would make more power at higher rpms but then i cant see it spooling faster than a vf "anything". Do you have experience/dyno sheet of a 16g vs vf39,34? Just curious where youre getting your info from.
Also, I dont see how a turbo upgrade with an ots map is a waste of money considering the map is free and at anytime when money permits, it can be re-tuned for its true potential.
90k on motor w good compression.
I'm actually on the hunt now for a vf39 which ive already located a few for a good price. If i came across a vf34 that was in good condition for cheap id go for it but seems unlikely. And why would I look for JDM pinks when I could just get higher flowing top feed injectors? As for the 16g, i'm not looking for any at the moment. As for the fp16g (discontinued or not) I will never look for. I was just using it as an example to get a vf over it.My info is coming from 11 years of common knowledge on Subarus. The IHI VF turbos are cheap, that's why people get them; not because they were ever the best performing because they aren't. Until the EVO3 16G was replaced by larger variants of the 16G, it was regarded as the best turbo for 2.0L WRXs. It spooled faster than and made slightly more power than the OEM STI turbos. IMHO you are on a wild goose chase since there is no distinguishable performance difference between the VF34 and a 39/43. Why would you look for a turbo that's getting harder and harder to find because nobody has bought them new for many years (meaning they are all higher mileage) when you can catch a USDM STI turbo for $250-350 just by spitting in the wind?
As for the OTS maps there are multiple reasons on why it's a bad idea, many are related to the fact that you're having to run a crap setup to use it:
- You're stuck with a slow (compared to others) spooling FP16G that makes a decent amount less power than competitors.
- You have to run JDM STI Pink injectors, which are harder to find than USDM STI/2.5L WRX injectors AND more expensive when they they perform nearly identical (Pinks are slightly better at peak flow)
- STI Pinks do not flow well enough for a good 16G, you need 650cc if you want enough headroom.
- Rather importantly, did you know the FP16G has been discontinued for years?
In addition:
- This map leaves so much power on the table it's ridiculous. Cobb claimed 249 whp and 229 wtq , which is 10 or less whp than what can be achieved with a good custom stage 2 tune on the stock TD04 and less torque.
- Cobb's maps are nothing but base maps marketed as "free maps". They don't provide the greatest driveability or power as they were never intended to. Most people will tell you that base maps are only good for allowing you to drive to a tuner to get custom tuned.
- Cobb's OTS maps don't take well to all cars. There are too many variables in place for a one size fits all to really live up to the name. Different environment issues, different gas, different states of car health, etc. Some cars will blow up from using these maps because of it.
