Well if i had a few extra thousand laying around id proly get somthing larger (20g) with some of that thousand paying for a good tune. But since the 16g is so comparable to the vf34 and 39 and cobb has ots maps for them, im looking for a used sti turbo for now and then ill upgrade down the road.
From what ive searched it seems the oem turbos are so much more reliable than FP. I would go with the fp16g but since im buying used and taking into consideration the vf34,39 are too similar to the 16g and evidently have proven to be the most reliable, it almost seems like a no brainer.
- A 16G is better than a VF anything. They spool faster, are more efficient at higher boost levels, and make more power.
- Anyone who uses an OTS map on a turbo upgrade might as well just keep their money and not spend it at all. Why waste so much money on parts and not actually use them to their true potential?
- FP's 16G sucks.
FP makes better larger turbos (FP Green HTA and up, especially the Red) but offers under-performing smaller turbos while Blouch makes better smaller turbos (EVO3 16G/16GXT thru Dom 1.5XTR) and super laggy larger turbos..
sorry, just re-read the post and realized what you were talking about. Yes, you cant run a vf and a 16g on the same tune. What I meant was run them both with the same tuner. A good tune for the vf. A good tune for the 16g. I'm asking your opinion IF youve experienced the difference. From what ive heard, its a 50/50 with what people are more happy with. Thanks.
okie doke. opinions are always appreciated though.
