AFR for 98 fuel? - Subaru WRX Forum
post #1 of 9 Old 08-18-2012, 04:49 AM Thread Starter
joker97's Avatar
joker97 is an unknown
AFR for 98 fuel?
Hi there ... complete noob who has done too much yet not enough reading on romraider tuning ...
the thing is they keep saying target AFR 11.1-11.3 but that is for 91-93 fuel ... what is the optimal AFR for 98 fuel since it is more resistant to detonation? same as the rest? or closer to 12?
joker97 is offline
post #2 of 9 Old 08-18-2012, 07:17 AM
93 Oct converts to 98 RON, so that's about where it should be. Really depends on how the map was set up.
post #3 of 9 Old 08-21-2012, 11:50 AM
Alexmartynyuk's Avatar
Alexmartynyuk is an unknown
depends on the setup but around 11:1 is good, the leaner you go the higher egts get and then you melt stuff.
Alexmartynyuk is offline
post #4 of 9 Old 08-21-2012, 10:35 PM
And you scar your cylinder walls...
post #5 of 9 Old 08-22-2012, 01:18 AM Thread Starter
joker97's Avatar
Haha yeah oops ... Unrelated dumb question ... How come the stock maps run 9.0 to 10.0 afr on their maps!!! If i tune it down to 11.1 will we save fuel on boost?
joker97 is offline
post #6 of 9 Old 08-22-2012, 01:21 AM Thread Starter
joker97's Avatar
(and get more power!)
joker97 is offline
post #7 of 9 Old 08-22-2012, 06:04 AM
Leaning it out will help.... but If I'm not mistaken other parameters need to be adjusted as well. Keith and others may know more
post #8 of 9 Old 08-22-2012, 08:56 PM
Yes you need to adjust timing, fuel, wastegate duty cycles and all kinds of things. The 9-10 AFR is a safety feature to keep the motor from blowing up. I have seen Cobb even use numbers that low.
post #9 of 9 Old 08-22-2012, 08:57 PM
Kind of unrelated, but it is...Do the NZ cars run the same ECU as the Aussie cars?
