accessport Dyno problem - Subaru WRX Forum
post #1 of 4 Old 03-03-2010, 07:25 PM Thread Starter
ridedh2 is an unknown
so i keep trying tthe dyno mode on the AP and im getting no where. it doesnt get any further than it saying "checking engine..." and thats it. ive waited a few minutes and nothing.
Also, for the weight input of the car does anyone know what i should put? just have a Invidia full tbe. and what do i would when it asks how many parts to choose from 1-5?
hope i make sense and thanks
ridedh2 is offline
post #2 of 4 Old 03-04-2010, 12:46 PM
Smokin'Joe's Avatar
Smokin'Joe is more helpful than not
I've had that happen with mine before. I just reset the AP and try again. The one time it happened to me I had to reset it about 3 times until it worked and haven't had the same problem since. not sure why it did that at all though... The manual says the curb weight (all up) is 3,229 for the 5 door model. I believe the sedan is a little heavier. I have about 60 lbs of stuff in the car and with the down pipe and lightened crank pulley I can take off around 12 lbs (that stock pipe is freakin heavy in comparison!) so I usually just put 3250 for general since I don't know the exact measurement, lol. I'm not sure what the 1-5 option is though ??? Isn't it asking you what gear you're going to use rather than a part? Then select your rpm range. I typically go from 2,000 to 6,500 for the full band pre turbo spool 'till after it drops off a good bit for good measure. I hope that helps a little. Good luck getting that thing to work, just be patient with it, it's only a machine, haha.
Joe
Only use roads to get to the dirt; Then keep it sideways! >;D
Smokin'Joe is offline
post #3 of 4 Old 03-04-2010, 12:48 PM
Smokin'Joe's Avatar
Curb Weight 3,174 lbs (4-door manual)/3,175 lbs (5-door manual) From the manufacturer website. That's for the base model.
Curb Weight 3,229 lbs (manual only) for the premium model.
Joe
post #4 of 4 Old 03-04-2010, 02:05 PM Thread Starter
thanks man... how do you reset it exaclly?
ridedh2 is offline
