About Hydra Ems - Subaru WRX Forum
post #1 of 10 Old 07-05-2006, 11:55 PM Thread Starter
rodrigo.diaz is an unknown
About Hydra Ems
Its a good choice the Hydra Ems for a daily driver, considering is one of the only chances on EMS for my car(non USDM STI)
Right now i buy the 3" turbo back,TMIC,Headers.
In the future I'm considering a FP green, Injectors or May be go rotated but to much lag is an issue for me because i use the car like a daily driver and i run lots of milles in the highway.
Comments appreciated
rodrigo.diaz is offline
post #2 of 10 Old 07-06-2006, 09:17 AM
I am running a Hydra on my daily driver.. Once it's setup it's just like a stock ECU in the way it operates.. Just make sure you don't need emissions as the hydra WILL not work with the OBDII, or should I say the OBDII will not work with the Hydra so it will NOT pass emissions...
post #3 of 10 Old 07-06-2006, 09:28 AM
S.M.06Rex's Avatar
S.M.06Rex is an unknown
I have a quick question?
What is an Fp Green? I Have heard it before but don't know what it is.
Alex- 06 Wrx
-Cobb Stage II
S.M.06Rex is offline
post #4 of 10 Old 07-06-2006, 09:37 AM
FP Green is a "Forced Performance Turbo" The Green relates to the size.. There is also a Red..
http://www.forcedperformance.net
http://linux.forcedperformance.net/m...Code=WRX-Turbo - Fp Green info Page
post #5 of 10 Old 07-06-2006, 09:38 AM
I have a rotated mount GT35R with a .82 exhaust housing and the lag with the 2.5 block is not even noticable.. It's a GREAT daily driver with MASSVIE power..
post #6 of 10 Old 07-06-2006, 10:13 AM Thread Starter
gt-35
MMMM I'm begin to like more the gt-35 kit, so it can be use for a daily driver.
What are mods to compare with my future mods????
Thanks.
post #7 of 10 Old 07-06-2006, 10:44 AM
Here is my mods..
Engine / Transmission
Magnus Intake - Extreme PSI (Junk!!! Don't buy one)
STI Short Block - Kerven Subaru
CP Forged Pistons - Axis Power Racing (allowing me to boost up to 24psi)
Perrin Crank Pulley - PDX Tuning
NGK BKR7E spark plugs - Gaped to 0.028
Comitec Head Gaskets - Horse Power Freaks
ARP Head Bolts - PDX Tuning
New 2.0L Heads - Axis Power Racing
Port & Polish - Axis Power Racing
Stage 2 Racing Valve train - Axis Power Racing
- Dual Spring Valve springs
- Titanium Retainers
- New Buckets
- New Shims (Shim under Bucket Design)
- New Keepers
Kelford Cams - Axis Power Racing
- 272 Intake with 10.5mm Lift
- 264 Exhaust with 10.5mm lift instead of 10.2mm
Stainless Steel Black Nitrided Valves - Axis Power Racing
STI Short Shifter - Came with car when purchased Used
PPG 1-4 Straight Cut DogBox w/ Upgraded 5th Gear Hub – AndrewTech Automotive
PPG Front LSD – AndrewTech Automotive
Kaaz Rear LSD – AndrewTech Automotive
ACT Full Faced organic Clutch (Thinking about getting a SPEC Stage 3)
ACT Pressure Plate
ACT Street Light Flywheel
Fuel Delivery
Hydra Stand Alone ECU with Wide Band - Tuning done by Phil at Element Tuning
Launch Assist & Anti Lag Add-on for Hydra EMS – Element Tuning
Perrin Fuel Rails - PDX Tuning
1200cc Fuel Injectors - RC Engineering
Walbro Upgraded In-Tank Fuel Pump
Aeromotive Fuel Pressure Regulator - JSC Speed
Braided Kevlar Fuel Lines w/ AN Fittings - Summit Racing
Induction / Exhaust
Garrett GT35R Twin Ball Bearing Turbo w/0.82 Exhaust housing - ATP Turbo
Perrin Front Mount Intercooler - Race Dezign (PITA to install on my car)
Perrin Radiator Hose Kit – Race Dezign
Koyo Polished Radiator - Rhythm Racing Motorsports
HKS SSQV Blow Off – Ultimate Racing
Blitz Power SUS Intake (With custom 4” runner and MAS delete)
Custom 3" Catless Down Tube - Ultimate Racing
Custom 38mm Catless Up-Pipe - Ultimate Racing
TiAL 38mm External Waste Gate (18lb Spring) - Ultimate Racing (Now Boosting to 24PSI)
Custom 38mm Dump Tube - Ultimate Racing
Greddy EVOII Cat Back Exhaust
Custom Header - Element Tuning (Still Back ordered)
Suspension
Perrin Tuner Sport Springs - Race Dezign
Perrin Front Sway Bars - Race Dezign
Perrin Rear Sway Bars- Race Dezign
Perrin Front End Links - Race Dezign
Perrin Rear End Links - Race Dezign
Perrin Rear Sway Bar Solid Mounts - Race Dezign
Perrin PSRS - Race Dezign
Misc Other Parts
TurboSmart Eboost2
Yellow Top Optima Battery - Auto Zone
Autometer "Phantom" Gauges (EGT / Oil Pressure / Fuel Pressure) - Summit Racing
Autometer Pro Shift Light (Blue) - Summit Racing
Pioneer AVIC-N1 Head Unit - Best Buy (Discount all the way)
Viper Security System w/ Remote Start & Automated Windows - Best Buy (Discount all the way)
JL Audio 500/1 - Local Shop
JL Audio 10W7 - Local Shop
18” SSR Comps (Competition Silver) - Tire Rack
Toyo Proxies TS-1 225/40ZR18
Kartboy Front shifter Bushing - PDX Tuning
Kartboy Rear Shifter Bushing - PDX Tuning
Also if you look in my Profile you will see a dyno sheet with the TQ and HP curve.. At the time of the Dyno sheet I had the stock Manifold on and the Perrin TMIC....
post #8 of 10 Old 11-04-2007, 10:12 PM
wrxman420's Avatar
Is there ANY possible way to get the hydra ems to work with an obd2 port? I really really want a hydra, but unfortunately in a few years i will have to comply with emmissions again.
wrxman420 is offline
post #9 of 10 Old 11-05-2007, 07:47 AM
The Hydra, or any standalone, is kinda overkill on most setups out there.If your intent is to use it a s a full out race/drag car then absolutly.But for most 18G and smaller turbos it's a waste.Enginuity has had sucess changing/rescaling the MAF limits to allow past 300g/s and with the 32 bit ECU's speed density of the factory sensors.Any standalone will absoluty have way more features (anit-lag,alky/meth injection,launch control,wastegate comp per gear,extra injector drivers..) but unless your going to use them thats a big chunk of change to spend for something that cheaper EM can do(Utec,Cobb,Opensource..).
dumdum is offline
post #10 of 10 Old 11-05-2007, 07:49 AM
Nope.The Hydra doesn't have OBDII capabilities/programming.
dumdum is offline
