3rd gear log--- enginuity - Page 2 - Subaru WRX Forum
post #16 of 53 Old 11-19-2007, 01:03 PM
Originally Posted by Labukas19 View Post
that was 3rd gear..
In 3rd gear @ 3K rpm i am regestering 40mph.Just look at the log i posted.I have a stock tranny.Thats how i know you were not in 3rd gear.
dumdum is offline
post #17 of 53 Old 11-19-2007, 01:04 PM
did another 4th gear fromm 2000 rpm... on xpttuning
3rd gear..not 4th gear.
dumdum is offline
post #18 of 53 Old 11-19-2007, 01:05 PM Thread Starter
Images: 14
Labukas19 is more helpful than not
ahh thats what i meant 3rd gear...
i def. was in 3rd gear.. lol...
2001 COBRA
Labukas19 is offline
post #19 of 53 Old 11-19-2007, 01:09 PM Thread Starter
Images: 14
im at 36 in 3rd@3k
2001 COBRA
post #20 of 53 Old 11-19-2007, 01:12 PM
Originally Posted by Longshot View Post
Ron, is that your "knock" correction profile?
Yup.You have to go back and change your primary ignition timing table so that you are running the same amount of timing overall.Initial/primary ignition timing+KC+IAM+other unknown tables = total timing advance.I know there was a new table found that showed timing comp per cylinder.The #3 & #4 were reciving -2.11* from the main map.I set that to zero since i now have a header & balanced injectors with alittle more injector headroom.
dumdum is offline
post #21 of 53 Old 11-19-2007, 01:16 PM
im at 36 in 3rd@3k
Dude,your original log was not in 3rd gear,that's all i'm saying.Re-read my first post AFTER i posted my log...@65mph you were @ 2900rpm!!
dumdum is offline
post #22 of 53 Old 11-19-2007, 01:21 PM Thread Starter
Images: 14
i kno what 3rd gear is.. not trying to be mean but read what it was in.. i had it in KPH at first. not MPH.. i had to switch it to mph. did that for the other logs...
it was 65 KPH... i was like wtf is he talking about! i no im not in 4th! that would just be retardted if i didnt no ### gear im in ahah
2001 COBRA
post #23 of 53 Old 11-19-2007, 01:27 PM
Your link is dead.Put
[ code ]
copy/paste directly from open excel file log
[ /code ]
No spaces before and after code and /code,had to do that or something stupid would happen.Just like when you quote someone.You will have to go back and manually shorten the colum headers to get the them to line up right = change enginespeed -to-RPM,Intake Air Temp-to-IAT.
dumdum is offline
post #24 of 53 Old 11-19-2007, 01:30 PM
I didn't catch the KPH!!! Yeah everything in standard measurements or this kinda stuff happens.Trying to convert KPH-mph,bar-psi,C°-F° = to much effert for me!!
dumdum is offline
post #25 of 53 Old 11-19-2007, 01:35 PM
Longshot's Avatar
Ron, I'm doing another log after work today once I pick up my car (new tires thank god) and install my short shifter. I'll let you know what I get. Can Labukas's problem relate or in fact be exact as mine?
DTRacing Tuned
Longshot is offline
post #26 of 53 Old 11-19-2007, 01:39 PM
Yes in the fact that you are both using OTS(off the shelf) tunes.Especially now since most gas stations are switching over to winter gas or use ethenol blends.Things people don't ever consider.Also I run blanced injectors for a reason.Before cleaning/balancing there was a 6% flow difference between the 4.Now they are within 1.5%.The ECU has no idea what your injectors are really flowing.I just does the same pulse width/duty cycle for all 4 if you see where i'm going.
dumdum is offline
post #27 of 53 Old 11-19-2007, 01:47 PM
Longshot's Avatar
I see, interesting. It's what you told me before that maybe I got some "bad gas." If this is a reoccuring problem through the winter is there some tweaking that can be done to correct it?
DTRacing Tuned
Longshot is offline
post #28 of 53 Old 11-19-2007, 01:52 PM Thread Starter
Images: 14
Code:
Time	IAM	MAF V	Load	(rpm)	Timing	IAT	KC	psi	MAF	WG	Throttle	(mph)
20:10.8	16	1.46	0.34	2026	32.5	45	0	-10.74	5.69	37.25	1.57	29
20:11.2	16	1.46	0.34	2011	32.5	45	0	-10.74	5.75	57.25	1.57	29
20:11.3	16	2	0.61	2023	33	45	0	-9.29	13	69.41	15.69	28
20:11.5	16	2.48	1.96	1984	41.5	45	12	0.15	39.56	81.18	100	28
20:11.7	16	2.5	2.06	2022	40.5	45	11.5	0.73	34.67	87.45	100	28
20:11.9	16	2.56	2.15	2109	39	45	11.5	1.16	37.12	87.45	100	28
20:12.1	16	2.6	2.22	2176	36.5	45	11.5	1.89	39.98	87.06	100	28
20:12.3	16	2.58	2.3	2225	32	45	11	2.61	42.73	87.06	100	28
20:12.5	16	2.68	2.39	2254	28.5	45	10.5	3.34	45.71	86.67	100	28
20:12.7	16	2.74	2.52	2315	26	45	10.5	4.35	49.32	86.67	100	29
20:12.9	16	2.82	2.7	2399	25	45	10	5.08	54	86.27	100	29
20:13.1	16	2.88	2.86	2480	23.5	45	9	6.09	59.93	86.27	100	29
20:13.3	16	2.98	3.06	2549	22	45	8.5	7.11	64.82	85.88	100	31
20:13.5	16	3.1	3.37	2626	19.5	45	7.5	8.56	73.5	85.88	100	31
20:13.7	16	3.18	3.71	2718	17.5	45	6.5	10.16	83.67	85.88	100	34
20:13.9	16	3.32	4.13	2790	14	43	5	12.62	97.35	85.88	100	34
20:14.0	16	3.48	4.49	2876	10.5	43	4.5	15.09	108.74	85.88	100	34
20:14.2	16	3.44	4.48	2990	10	43	4.5	16.11	112.11	85.88	100	36
20:14.4	16	3.5	4.44	3070	10.5	43	4.5	15.96	114.66	85.88	100	36
20:14.6	16	3.56	4.44	3159	10.5	43	4.5	15.96	116.76	85.88	100	39
20:14.8	16	3.62	4.5	3288	10	43	4.5	16.11	121.91	85.88	100	39
20:15.0	16	3.7	4.62	3362	9.5	43	4	16.54	129.88	85.88	100	39
20:15.2	16	3.74	4.73	3482	8.5	43	4	16.83	137.7	85.88	100	42
20:15.4	16	3.72	4.73	3582	8.5	43	4	16.69	141.81	85.1	100	42
20:15.6	16	3.76	4.73	3674	9	43	4	16.69	144.54	84.31	100	45
20:15.8	16	3.8	4.76	3780	9	41	4	16.83	149.44	84.31	100	45
20:16.0	16	3.84	4.73	3904	9.5	41	4	16.83	154.5	83.53	100	48
20:16.2	16	3.9	4.75	4006	9.5	41	4	16.98	159.02	82.75	100	48
20:16.4	16	3.9	4.76	4092	9.5	41	4	16.98	162.61	81.96	100	48
20:16.6	16	3.96	4.79	4223	9	41	4	16.98	168.24	80.78	100	52
20:16.8	16	4	4.86	4343	9	41	4	16.98	176.58	79.61	100	52
20:17.0	16	4.04	4.87	4435	9.5	41	4	17.27	180.42	76.47	100	56
20:17.2	16	4.06	4.85	4529	10	41	4	17.27	183.93	73.73	100	56
20:17.4	16	4.08	4.84	4641	10.5	41	4	17.27	187.62	70.2	100	60
20:17.6	16	4.1	4.84	4798	11	39	4	17.12	192.11	65.88	100	60
20:17.8	16	4.12	4.81	4867	11.5	39	4	16.83	194.35	61.96	100	60
20:18.0	16	4.14	4.78	4954	12	39	4	16.69	197.71	59.22	100	63
20:18.1	16	4.16	4.75	5064	13	39	4	16.4	200.33	56.47	100	63
20:18.3	16	4.18	4.7	5165	14	39	4	15.96	202.6	56.47	100	66
20:18.5	16	4.18	4.65	5259	14.5	39	4	15.67	203.4	58.82	100	66
20:18.7	16	4.2	4.62	5326	15.5	39	4	15.24	205.8	62.75	100	66
20:18.9	16	4.22	4.59	5494	16	39	4.5	15.09	209.8	65.88	100	70
20:19.1	16	4.22	4.56	5614	16.5	39	4.5	15.09	212.6	69.02	100	70
20:19.3	16	4.26	4.55	5699	17	39	4.5	14.8	217	72.55	100	73
20:19.5	16	4.26	4.5	5827	17.5	39	4.5	14.8	217	73.33	100	73
20:19.7	16	1.62	0.3	5647	11.5	39	0	-5.08	9.43	0	0	73
20:19.9	16	2	0.38	5527	11.5	39	0	-9.58	16.53	0	0	76
20:20.1	16	2.16	0.51	5201	11.5	37	0	-9.87	21.63	0	0	76
20:20.3	16	2.16	0.56	4738	11.5	37	0	-9.72	22.06	0	0	78
20:20.4	16	2.14	0.58	4394	11.5	37	0	-9.58	21.2	0	0	78
20:20.6	16	2.06	0.55	4144	11.5	37	0	-9.43	19.35	0	0	78
20:20.8	16	1.96	0.44	3832	11.5	37	0	-10.16	16.46	0	0	78
20:21.0	16	1.9	0.5	3529	11.5	37	0	-9.58	15.29	0	0	78
20:21.2	16	1.82	0.48	3246	11.5	37	0	-9.29	12.74	0	0	75
20:21.4	16	1.76	0.43	3055	11.5	37	0	-9.58	10.74	0	0	75
20:21.6	16	1.7	0.36	3103	11.5	39	0	-9.87	9.53	0	0	75
20:21.8	16	1.58	0.31	3032	11.5	39	0	-10.3	7.82	0	0	72
xpt stage II
2001 COBRA
post #29 of 53 Old 11-19-2007, 01:54 PM
The problem with the free maps is they are starting points,not garenteed maps.I still have your email address so let me know if you have a manual or auto and i will send you a quick revision of that map that might work better.Basiclly i will just mess with the timing alittle.Do you still have the stock up-pipe?
dumdum is offline
post #30 of 53 Old 11-19-2007, 01:56 PM Thread Starter
Images: 14
who him or me???
my map wasnt free.... i paid the $52 to have the extreme xpt stage 2... i got that because i didnt want to do alot of tuning... lol but will my IAM go back down to 13? or are they going to stay at 16?
2001 COBRA
