3rd gear log--- enginuity - Subaru WRX Forum
post #1 of 53 Old 11-19-2007, 09:05 AM Thread Starter
Images: 14
Labukas19 is more helpful than not
hey guys just did a third gear pull. i dont like the knock. i got 11.5 and then pulled hella timing... let me know what you think... this is an XPT stage 2 map 2004 wrx. TBE catless, catless up pipe, k&n drop in filter.
2001 COBRA
Labukas19 is offline
post #2 of 53 Old 11-19-2007, 09:06 AM Thread Starter
Images: 14
what the heck i uploaded it as an attactment...
2001 COBRA
post #3 of 53 Old 11-19-2007, 09:10 AM Thread Starter
Images: 14
well its saying invalid file.. how do i change it? its a .csv
2001 COBRA
post #4 of 53 Old 11-19-2007, 09:33 AM Thread Starter
Images: 14
well heres a link to it on xpttuning http://www.xpttuning.com/osecuroms/v...hp?p=7317#7317
thanks!
2001 COBRA
post #5 of 53 Old 11-19-2007, 09:41 AM
Longshot's Avatar
You don't, this site gives the allowed file extensions and excel is not supported. I don;t really know a good way to post logs in this site. I don't think a print screened pic of it will do either.
EDIT: there ya go, that's about the only way.
DTRacing Tuned
Longshot is offline
post #6 of 53 Old 11-19-2007, 09:47 AM
Longshot's Avatar
I see your IAM is at 13 as mine was a last week. You also forgot to log atmospheric pressure, aka boost in PSI. Read my correspondance with DumDum titled "IAM at 13" about me having the same issue as you, obviously in the "tuning and EM forum."
As soon as I reset my ecu, it went back up to 16. I need to log it again though to make sure, probably today.
DTRacing Tuned
Longshot is offline
post #7 of 53 Old 11-19-2007, 10:10 AM Thread Starter
Images: 14
so just reset it by the battery? leave it off for about 30 mins right? then back and then log it? Thanks! I logged everything xpt said to do... ill check my list again...
isnt the boost cell g?
thanks!
2001 COBRA
post #8 of 53 Old 11-19-2007, 10:21 AM
Longshot's Avatar
thanks!
I was logging something different for boost, not the corrected one in column G (although I do log that one also). For the ecu reset just disconnect the negative battery terminal and press the break down for 5-10 seconds. Then wait only a minute or 2 and reconnect and it should be all set, you'll know ### your clock will change, as well as presets on the radio. Do that and go for another 3rd gear pull from 2k to redline at WOT.
DTRacing Tuned
Longshot is offline
post #9 of 53 Old 11-19-2007, 10:27 AM Thread Starter
Images: 14
just wanted to make sure thats what you meant with reseting it. dont have to reflash or anything right...
2001 COBRA
post #10 of 53 Old 11-19-2007, 10:48 AM
Try to copy and paste the file in code
Code:
Load	IAM 	PSI	RPM	Timing	IDC	IAT	KC	G/S	WDC	TOA	MPH
0.33	16	-9.24	2008	48.5	3.86	39	10	10.99	16.47	2.75	28
0.33	16	-9.26	2028	48.5	3.89	39	10	10.99	16.47	2.75	27
0.33	16	-9.24	2004	48.5	3.85	39	10	10.99	16.08	2.75	27
0.33	16	-9.22	1999	48.5	3.84	39	10	11.1	16.47	2.75	28
0.33	16	-9.18	2012	48.5	3.87	39	10	11.1	16.08	2.75	28
1.15	16	0.12	2038	26	12.61	39	10	42.78	24.31	94.9	28
1.25	16	0.85	2066	24	14.55	39	10	43.75	40	100	27
1.31	16	1.66	2142	23	15.99	39	10	47.72	52.16	100	27
1.38	16	2.49	2150	21.5	16.97	39	10	50.16	58.82	100	29
1.44	16	3.31	2227	21	18.53	39	10	53.45	57.65	100	29
1.5	16	4.1	2320	20	19.79	39	10	58.22	57.25	100	29
1.58	16	4.93	2348	19	21.9	39	10	62.32	56.86	100	29
1.67	16	5.86	2428	17	23.83	39	10	68.44	56.08	100	30
1.75	16	6.86	2518	15.5	25.78	39	10	73.5	55.29	100	30
1.86	16	7.97	2600	15.5	28.85	39	10	83.05	55.29	100	32
2.03	16	9.32	2687	14	32.67	39	10	91.87	55.29	100	32
2.25	16	11.23	2752	13.5	40.7	39	10	107.24	55.29	100	34
2.53	16	13.88	2869	13	47.74	39	10	124.87	55.29	100	34
2.81	16	16.8	2958	12.5	54.91	39	10	139.46	55.29	100	37
2.96	16	18.93	3146	13	61.74	39	10	147.66	55.29	100	37
2.99	16	19.76	3232	13	64.13	39	10	158.08	54.12	100	40
3.03	16	19.84	3357	13	69.5	37	10	166.37	52.55	100	40
3.02	16	19.53	3549	12.5	71.93	37	10	176.92	50.98	100	43
3.02	16	19.43	3666	12.5	75.07	37	10	183.98	49.8	100	43
2.93	16	18.72	3818	13	74.94	37	10	185.8	49.41	100	47
2.94	16	18.83	3941	13	77.35	37	10	192.86	49.41	100	47
2.96	16	19.07	4125	13	84.49	37	10	198.46	49.41	100	47
2.97	16	19.01	4223	13.5	86.48	37	10	207.4	49.41	100	51
2.92	16	18.64	4355	13.5	88.47	37	10	210.6	49.41	100	51
2.93	16	18.41	4499	13.5	91.18	37	10	221.51	52.16	100	55
3	16	18.95	4621	14	95.62	37	10	230.01	54.12	100	55
3	16	19.28	4696	14.5	98.18	37	10	237.31	53.73	100	58
2.97	16	19.01	4860	15	100.58	37	10	240.76	53.33	100	58
2.95	16	18.51	4957	15	101.52	36	10	244.67	54.12	100	62
2.9	16	18	5123	15.5	103.82	36	10	248.72	54.9	100	62
2.86	16	17.52	5212	15.5	102.29	36	10	247.37	54.9	100	66
2.82	16	16.96	5319	15.5	104.39	36	10	250.97	54.9	100	66
2.79	16	16.51	5450	15.5	103.48	36	10	252.33	54.9	100	70
2.73	16	16.03	5510	15.5	104.63	36	10	251.43	54.51	100	70
2.7	16	15.62	5593	15.5	104.99	36	10	251.88	54.12	100	73
2.65	16	15.26	5703	16	104.64	36	10	251.88	53.33	100	73
2.61	16	14.91	5814	16.5	104.18	36	10	255.03	51.76	100	73
2.58	16	14.58	5854	17	105.31	36	10	253.68	51.37	100	76
2.53	16	14.33	5948	17.5	104.26	36	10	254.13	50.59	100	76
2.49	16	14.06	6082	18.5	103.89	36	10	253.68	50.2	100	79
2.47	16	14.06	6178	19	105.43	36	10	253.68	50.2	100	79
2.43	16	13.85	6193	19	104.37	36	10	251.88	50.2	100	81
2.42	16	13.88	6266	21.5	104.26	36	10	254.13	50.2	100	81
2.37	16	13.85	6361	22	103.13	36	10	251.43	50.2	100	84
2.36	16	13.88	6471	22	104.92	36	10	250.98	50.2	100	84
2.32	16	13.9	6488	22.5	103.8	36	10	251.88	50.2	100	86
2.31	16	13.9	6579	22.5	103.86	36	10	253.23	50.2	100	86
2.28	16	14.02	6631	23	104.69	36	10	252.78	50.2	100	89
What do you mean by 11.5?You give no reference.
dumdum is offline
post #11 of 53 Old 11-19-2007, 11:27 AM
Well for starters that log doen't really tell you anything exept that you had knock due to the IAM.Sense you don't run a "10" KC type map nor did you log "feedback correction" or "fine correction" it makes it hard to see if and where your having knock without directly comparing the log against the actual map cell by cell.If you actually open up any of the ECU mappings and looked at how the various maps are laid out/constructed you would get a better understanding of what I'm talking about and why people go back and change their KC maps to "10's".Makes it much easier to find where your knocking and where the ECU is pulling timing.So if you log feedback & fine correction where they show neg #'s is how much timing is being puled and where (load & rpm).Your log looks like a 4th gear log since at 65 mph you show 2900 rpm.You need a good 3rd gear log from 2000rpm to 6500 or redline and thats it.Reset the ECU.Warm up the car and relog with a IAM of 16.The IAM dropping point will show heavy knock as well.You log was all 13's so knock could have been stabilized already with the IAM being dropped.
dumdum is offline
post #12 of 53 Old 11-19-2007, 12:18 PM Thread Starter
Images: 14
that was 3rd gear.. just did another log with the ecu reset. iam at 16... isnt the knock count correction in degrees the knock im getting? im at work so im kinda skimming throught this to hurry up... but heres the link to the new log... http://www.xpttuning.com/osecuroms/v...hp?p=7323#7323
thanks for the help so far..
also Im logging everything XPTtuning said to log...
2001 COBRA
post #13 of 53 Old 11-19-2007, 12:28 PM Thread Starter
Images: 14
did another 4th gear fromm 2000 rpm... on xpttuning
2001 COBRA
post #14 of 53 Old 11-19-2007, 12:37 PM Thread Starter
Images: 14
im not trying to get every spec of hp out of it. i just want to make sure it is safe... so let me know.... thanks!
2001 COBRA
post #15 of 53 Old 11-19-2007, 01:51 PM
Longshot's Avatar
Code:
Ron, is that your "knock" correction profile?
DTRacing Tuned
Longshot is offline
