08 wrx CEL - Subaru WRX Forum
post #1 of 10 Old 02-24-2009, 04:14 AM Thread Starter
On_3_Go's Avatar
On_3_Go is an unknown
08 wrx CEL
Whelp long story short, I was headin down the highway and wanted to let the car air out alittle in 5th. Alittle into 5th the car jerked and the Cel came on, code P0244 wastegate solenoid A range/performance plus Cyl 1 misfire. Im currently runnin XPT stg 2 Aem Cia, Invidia catless DP, Spt CB. I dunnp what could have caused the problem i know its overboost code. Now the car doesnt sound the same sounds like the turbo is always spooling, and not the normal sound. Like its over workin itself. But i cleared the codes and test ran the car and everything was fine.
Please chime in
On_3_Go is offline
post #2 of 10 Old 02-24-2009, 06:49 AM
The car overboosted.It happens.Since your running the XPT map email Braiden(XPT) and maybe he can moddify the map.Sounds like the wastegate duty compensation per IAT needs tweaking and maybe the turbo dynamics mapping.
dumdum is offline
post #3 of 10 Old 02-24-2009, 07:19 AM Thread Starter
On_3_Go's Avatar
Im having problems with the logger, i cant seem to get romraider to connect its driving me crazy!!! Any suggestions?
FYI it has been freezing cold around my area for the past few months and i havent had a problem running the map since i have flashed it. Dunno if that would help but figured id just throw that out there
On_3_Go is offline
post #4 of 10 Old 02-24-2009, 08:54 AM
It won't always do it...but, I'm sure the cold air was the culprit. It just needs some tweaking. I can't help you with the logger. But, I'd say to give braiden a e-mail. Like dumdum said.
post #5 of 10 Old 02-24-2009, 09:05 AM Thread Starter
On_3_Go's Avatar
Well listen to this. i just updated my ecuflash program to the new update and now none of my xpt maps will load into the program GRRRRR!!!! I shot him an email just waiting on a response
On_3_Go is offline
post #6 of 10 Old 02-24-2009, 04:48 PM
Thats because you have to go back and put the XPT definition file back into Ecuflash.Anytime you update Ecuflash the definition files are removed and replaced.
dumdum is offline
post #7 of 10 Old 02-24-2009, 06:51 PM Thread Starter
On_3_Go's Avatar
I got everything workin,Im hittin 11.5-11.7 on the a/fs with xpt stg 2 a hair rich
On_3_Go is offline
post #8 of 10 Old 02-24-2009, 07:46 PM
Wrxthekid's Avatar
Wrxthekid is an unknown
Hey fellas, what up? Yo this happen to me like a few months ago but i really didn't do anything to fix. I have my check engine light come on and i was going to go to a shop and get it checked the next day. I woke up but nothing was on it and the car seemed running fine. So just wondering if it just a whatever thing or what??
Wrxthekid is offline
post #9 of 10 Old 02-25-2009, 08:56 AM
Not every DTC requires the CEL to be constantly illuminated.Most DTC's have a drive cycle that will turn the CEL if the problem has gone away and not been repeated.Overboosting is a momentary thing.Cel goes away when the drive cycle is complete.Now something like bad coil pack or catless exhaust will cause a permanent problem that cannot be solved by running out the drive cycle because the problem is not momentary.The CEL will stay illuminated until the problem is rectified.
dumdum is offline
post #10 of 10 Old 02-25-2009, 08:58 AM
Thats lean for Subaru tuning.I don't think you quite understand how fueling goes for forced induction vehicles.It's not the same as the lean-rich ratios on a NA engine.Here is the stock primary fueling map from an 02 WRX (most others look the same)
dumdum is offline
