03 wrx tunning questions - Subaru WRX Forum
 7Likes
  • 1 Post By psinuse
  • 6 Post By BLAZE2099
post #1 of 10 Old 09-14-2013, 12:57 AM Thread Starter
waynedawg is an unknown
So ive been having some problems tunning after installing a new intake and was looking for advice of where to look next. ive been having p0171 cel off and on and my idle afr is ~17:1, however cruising afr is right on and WOT is 11.1:1. so far ive been playing with the tune, replaced some leaking vacuum lines, cleaned maf, and cleaned idle air sensor. The car runs seemingly fine little rough idle but barely noticable, CEL hasnt come back on yet but its only been 5 miles. i also have logs at idle and WOT if that would help, but any advice of what to check next would be appreciated.
MODS: un-equal length headers, short ram intake, silicone intake tube to turbo, cobb access port, running personally modified stage 1 map.
Thanks, Wayne
waynedawg is offline
post #2 of 10 Old 09-14-2013, 07:44 AM
Bov???
post #3 of 10 Old 09-14-2013, 10:52 AM
n8mcd is a helpful contributing member
Exhaust leak before the wideband sensor or shortly after will cause this.
It could also be a vaccum leak. But to lean it out that much it would have to be a pretty decent one.
n8mcd is offline
post #4 of 10 Old 09-14-2013, 01:51 PM
Why are you running a header on a basically stock car?
post #5 of 10 Old 09-14-2013, 03:51 PM
Hmmm, and what about the rest of the exhaust?
Catless up? Turbo back? You should have these to go along which would make you a stage two.
If not, I'm with PSInuse. And are you running a BOV!!???!?!!!!
post #6 of 10 Old 09-15-2013, 03:58 AM Thread Starter
hi again. i have stock BOV, header and up pipe is one piece and catless because im working on a budget and can only do 1 upgrade at a time it will make sense eventually just trust me lol. And there may be exhaust leak cause theres a flex joint in my header, i will check that out and see what i can figure out, thanks!
post #7 of 10 Old 09-15-2013, 06:03 AM
You'd be better off with a downpipe and full turbo back exhaust before ever needing a header.
arewmors likes this.
post #8 of 10 Old 09-15-2013, 12:50 PM
This is true, save and buy quick, your car will thank you for it.
You kinda went out of order
post #9 of 10 Old 09-15-2013, 02:00 PM Thread Starter
I found a small leak at flex joint ill see what i can do to fix it not sure if i should replace or weld up solid and get rid of flex joint. yes downpipe is coming next but im gonna run stock muffler, and no im not out of order i have reasons for everything ive done but thanks anyways.
post #10 of 10 Old 09-15-2013, 02:53 PM
Yea, guess we have no clue what we're talking about.
Best of luck
turmic, boo-key, 09bluewrx and 3 others like this.
